![]() | Home > In Car Electronics > Aftermarket head unit install question |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5117 ![]() ![]() ![]() |
You know you loose the top display and Nav
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 ![]() ![]() ![]() |
i tried to collate everything I learned into one post here https://www.rrsport.co.uk/forum/topic55744.html |
Fire1 Member Since: 19 Mar 2020 Location: Poole Posts: 34 ![]() ![]() ![]() |
Hi thank you, the description for the product says the nav and screen remain but you lose the nav sound is that what you meant? |
No.
Eskimo Member Since: 21 Oct 2018 Location: Worcestershire Posts: 72 ![]() ![]() ![]() |
As i understand it with this kit from Incartech you retain the use of the Nav/Info screen and just the sub stops working, unless you fit the additional Amp as suggested:
that is correct but imo the sub makes a big diff but thats just my taste |
MG I'm the same, All about the BASS!! |
The incartec is expensive for what it is.
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
Mines almost the same as yours although 2005 SC with Logic 7 and I changed the head unit for a Pioneer double din one and got all the kit from Incartec so that I could keep the Nav screen (more for aesthetics showing 4x4 info than functionality as now I use Waze or Maps in Apple carPlay by connecting my phone to the head unit. I bought a separate amp (for about £80) and fitted it under the rear drivers side seat keep the subwoofer. From memory, using this method all you lose is the centre speaker for the Nav (not noticeable). DEFINITELY get the subwoofer powered, don't lose it, it's worth it! I've been really happy with whole set up although after 2 years the steering wheel controls seemed to have stopped working for some reason but I haven't explored why yet. There's lot's of posts on here about these installs and IncarTec send really good instructions and are really helpful. Also spend £10-£20 on a decent trim removal set for the inner console and stereo surround parts. Running the cables was the trickiest bit (especially to the amp) but it's not too bad!Good luck and let us know how you get on.
2005 4.2L Supercharged Java Black - gone but was my first love. -------------------------------------------------------------------------------------------------------- If we all point our RR's in the same direction and accelerate at the same time can we turn back time? |
Do the speakers in the rear roof work ? |
All the speakers in mine work apart from the centre dash one (which if I'm correct is only for the NAV sound anyway).
Thanks for the info, I have done most of the top part around the head unit I have the seat to tackle tomorrow. Just a couple more questions if I may- the amp is under the drivers seat isn’t it and not the rear seats? If so did you have to remove the seat to fit the loom? When you fitted the loom where did you route it to reach centre console? TIA. |
Hi, glad you're making progress.
Well I finally got it in! A few struggles but not too bad.
