Home > Technical > Amber lean light
Simonhunt72
Amber lean light
Hi all
After a few months hassle free ,apart from.new battery, we have the above !!!! Came on about 5 weeks ago, then vanished ! Came back yesterday ,whilst driving straight?! Have checked if sensor was clean ,connections etc , all ok, anyone know if it can be tested, or where else to look,suspension holds up fine !
Thanks in advance
Post #598303 Wed Apr 29 2020 6:51pm
knwatkins
I would get the fault codes read.
Have you checked your DSC fluid level? Kev
Post #598305 Wed Apr 29 2020 7:07pm
What year car.
Please fill in profile
Post #598309 Wed Apr 29 2020 7:33pm
Simonhunt72
Hi guys
Sorry Andy K ,will sort that, it's a 2006 , checked the levels (behind headlight drivers side ) it's all good , fault code reader I have brings up nothing!!!!
Post #598311 Wed Apr 29 2020 7:53pm
knwatkins
You could try recalibrating your steering angle sensor. This has been known to cause this issue if everything visually looks okay. Kev
Post #598314 Wed Apr 29 2020 8:02pm
Simonhunt72
Thanks knwatkins, is there a thread on how to carry that out?
Post #598315 Wed Apr 29 2020 8:24pm
Could be air suspension
Need someone with a
Decent code reader as just guessing otherwise
I think fluid level is red light anyway
Post #598316 Wed Apr 29 2020 8:47pm
Simonhunt72
Was hoping to avoid garage, can the sensors be checked at all?
Post #598317 Wed Apr 29 2020 8:58pm
See if someone on here local to u has an iid
Post #598319 Wed Apr 29 2020 9:36pm
knwatkins
You'll also need a tool to calibrate your steering angle sensor. As Andy says though, we are just shooting in the dark without the codes.
Andy, I thought the amber light refers to the DSC only. It is also illuminated for air suspension faults too is it? Kev
Post #598324 Wed Apr 29 2020 11:26pm
Yeah.
DSC is the arrow circle with triangle in middle
Press dsc button and you will see
Post #598328 Thu Apr 30 2020 6:26am
I can't really remember as it was along time ago I had my pre-facelift, but I think the pre-facelift may have had a different icon for the DSC Switch/Warning lamp to the facelift variant
Post #598330 Thu Apr 30 2020 7:52am
Simonhunt72
Thanks guys, I'm down in somerset , know of someone local enough ,will take a visit
Post #598331 Thu Apr 30 2020 8:17am
knwatkins
That would probably explain my confusion then Col. I know the amber light is usually accompanied by the 'vehicle lean when cornering' message which was why I assumed this was DSC related. This must just be for the facelift variant. Kev
Post #598368 Thu Apr 30 2020 10:24pm
Simonhunt72
So it appears its a possible connection issue causing the light as it comes and goes, has had reader on it ,and showed no faults, so my question is.... where to start??!! May be where the sunroof drain was broken in passenger footwell? Any advice gratefully received all
Post #599593 Wed Jun 03 2020 10:30pm
