![]() | Home > Technical > Amber lean light |
| knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139
I would get the fault codes read.
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5138
What year car.
| Simonhunt72 Member Since: 13 Jan 2019 Location: Somerset Posts: 68
Hi guys
You could try recalibrating your steering angle sensor. This has been known to cause this issue if everything visually looks okay. Kev
Thanks knwatkins, is there a thread on how to carry that out? |
Could be air suspension
Was hoping to avoid garage, can the sensors be checked at all? |
See if someone on here local to u has an iid |
You'll also need a tool to calibrate your steering angle sensor. As Andy says though, we are just shooting in the dark without the codes.
Yeah.
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5153
I can't really remember as it was along time ago I had my pre-facelift, but I think the pre-facelift may have had a different icon for the DSC Switch/Warning lamp to the facelift variant
Thanks guys, I'm down in somerset , know of someone local enough ,will take a visit |
That would probably explain my confusion then Col. I know the amber light is usually accompanied by the 'vehicle lean when cornering' message which was why I assumed this was DSC related. This must just be for the facelift variant. Kev MY2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey MY2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
So it appears its a possible connection issue causing the light as it comes and goes, has had reader on it ,and showed no faults, so my question is.... where to start??!! May be where the sunroof drain was broken in passenger footwell? Any advice gratefully received all |
