![]() | Home > General > SD4 vs TDV6 general advice |
| Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436
I’ve driven a few cars with the 2 litre diesels and whilst they are ultimately not far off the mark at the useable top end, it’s how it gets there. The 3 litre is so relaxed and effortless, whilst the 2 litre is a lot more frantic.
| londonl Member Since: 23 Sep 2015 Location: London Posts: 15 |
That makes sense and seems aligned with what else I have read, also the constant straining of that probably doesn't do much good for the engine. Better to have too much power you don't use I would guess.
You can go right back to a model year 2015, mine has a DPF but not Adblue, they referred to it a as EU5.5? . Before I bought it I checked on the London ULEZ website and it was compliant. The model year 2016 also has adblue and is EU6 so therefore completely ok.
Thats excellent to know - and certainly widens the options. Is the infotainment (main screen I'm thinking here) much different between 15 and 16, it seems to change design around then - one with buttons on side to one with touchscreen along the bottom?
The infotainment changed at MY 16, around sept 2015.
Thank you - that is good to know, appreciating all the help on this.
What would anyone think to this?
My personal thoughts, a lot will depend how many miles you normally do a year, if it’s well under 10k then maybe it’s ok, for me I went slightly older but less miles, you would maybe get a better spec as well. Joined the X5 45e club
Thank you, the mileage does worry me a bit but thought good to get some feedback
HSE is bottom, then HSE Dynamic, Autobigraphy and SVR sits there somewhere.
