![]() | Home > Maintenance & Modifications > Lockdown |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9153 ![]() ![]() ![]() |
It rather depends what sort of use it normally gets. If you normally do short runs then the battery might be a bit low anyway. A smart charger left plugged in would keep it all nicely topped up. If you normally do decent runs, then the battery is probably nicely full so will sit for a couple of weeks just fine.
Disengaging and re-engaging the electronic handbrake is advisable every week or so.
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2025 ![]() ![]() |
Don’t put the park brake on, just leave in P. * Current: 2024 D350 Defender 90 on coils!
I always put the park brake on because my driveway is sloping. If I just use P, it puts excess strain on the gearbox which can be felt by a noticable clunk when moving out of P. All of my automatic cars have done this, so when parking I usually engage N, apply the park brake, release footbrake so the park brake takes the weight of the vehicle, then engage P. Kev
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 ![]() ![]() ![]() |
+1 ALWAYS use the Parking Brake the way Kev explains. As he says it protects the gearbox and exercises the parking brake mechanism- and if you don’t use it you lose it! |
pbcb2020 Member Since: 23 Jan 2020 Location: Cardiff Posts: 18 ![]() ![]() ![]() |
Thanks for all the advice guys. Much appreciated |
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 225 ![]() ![]() ![]() |
Definitely use it I had mine renewed after a few months of ownership purely because the previous owner had failed to use it. |
I'm leaving EPB off but every week, ignition on, EPB on then off a few times. Leave off. Ignition off * Current: 2024 D350 Defender 90 on coils!
