Home > Technical > Gearbox glitch
Devon Z
England 2005 Range Rover Sport TDV6 HSE Java Black
Gearbox glitch
I’ve done a lot of research but nobody has exactly the same issue. Only had my RRS 4 months and gearbox has been smooth as silk but occasionally she holds 1st and won’t change up unless I ease off the throttle then gently back on she changes up with no major clunk or noise, then all’s good again.
Doesn’t seem to be temperature related it’s done hot or cold, no recorded codes, no error messages. Supplying dealer had the fluid done by a LR specialist who I contacted and they done a flush and fluid change but didn’t change the filter.
Any thoughts?
Steve Steve
2005 2.7 TDV6 HSE, ongoing project.
1998 Volvo V70 R auto FWD, mothballed future project.
1999 BMW Z3 (owned from new) garage queen.
Post #596856 Sun Mar 22 2020 11:48am
Kevin
United Kingdom 2010 Range Rover Sport TDV8 HSE Alaska White
Have you checked your tyre pressures are correct. If one is low this can cause all sorts of problems in shifting. Kevin
Post #596859 Sun Mar 22 2020 1:25pm
Devon Z
Thanks for the reply, yes I have their all correct and front tyres are new and correct size rears are matching pair good tread. Steering angle sensor not showing an error on my Icarsoft code reader.
Steve Steve
Post #596862 Sun Mar 22 2020 3:54pm
make sure the brake pedal switch isn't sticky
Post #596863 Sun Mar 22 2020 6:01pm
gogsy1956
Mine does the exact same,,, I thought maybe it was just the way I was driving at the time. Sometimes I drive with very little variation on the throttle, especially at roundabouts or junctions,,, which is where I see this most. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #596864 Sun Mar 22 2020 7:20pm
Devon Z
I take it brake lights working correctly doesn’t necessarily mean the switch is working correctly?
How does the brake switch effect the gearbox? Could explain why it does it sometimes after I’ve held her on the foot brake for a while like at traffic lights?
Steve Steve
Post #596867 Sun Mar 22 2020 9:34pm
If it thinks your braking, it thinks you are going down hill and would benefit from engine braking ie a low gear
Post #596869 Sun Mar 22 2020 9:56pm
Devon Z
Ahh, she does tend to drop into 1st when slowing and cornering when I would normally expect to stay in 2nd or 3rd.
Steve Steve
Post #596870 Sun Mar 22 2020 11:11pm
Brit Plumber
Is it actually in 1st or is in 2nd? It could be different for other models but my car starts in 2nd unless I select first manually. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #596871 Mon Mar 23 2020 12:32am
Devon Z
I’m only assuming it’s 1st?
Steve Steve
Post #596874 Mon Mar 23 2020 10:14am
I think it's just supercharged models which start in 2nd
Post #596884 Mon Mar 23 2020 1:18pm
LandPhil
United Kingdom 2013 Range Rover Sport SDV6 HSE Ipanema Sand
https://disco4.com/forum/pulling-away-seco...ght=Second
This might help
Post #596885 Mon Mar 23 2020 1:55pm
Devon Z
Thanks for the replies and information, been out this morning and she’s driven faultless. I’ll monitor the situation and look at doing the steel sump and separate filter conversion soon.
Steve Steve
Post #596886 Mon Mar 23 2020 3:22pm
Scrumpy
That's normal for these cars. It knows you're talking about it so it's playing ball now! 2016 RRS SVR Estoril Blue
Post #596887 Mon Mar 23 2020 3:38pm
Devon Z
Very true Very Happy see how long it lasts? Steve
Post #596890 Mon Mar 23 2020 6:31pm
