![]() | Home > Technical > Gearbox glitch |
| Kevin Member Since: 06 Dec 2005 Location: Poole Posts: 9
Have you checked your tyre pressures are correct. If one is low this can cause all sorts of problems in shifting. Kevin |
| Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 321
Thanks for the reply, yes I have their all correct and front tyres are new and correct size rears are matching pair good tread. Steering angle sensor not showing an error on my Icarsoft code reader.
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5138
make sure the brake pedal switch isn't sticky |
| gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961
Mine does the exact same,,, I thought maybe it was just the way I was driving at the time. Sometimes I drive with very little variation on the throttle, especially at roundabouts or junctions,,, which is where I see this most. 2010 RRS, TDV8
I take it brake lights working correctly doesn’t necessarily mean the switch is working correctly?
If it thinks your braking, it thinks you are going down hill and would benefit from engine braking ie a low gear |
Ahh, she does tend to drop into 1st when slowing and cornering when I would normally expect to stay in 2nd or 3rd.
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849
Is it actually in 1st or is in 2nd? It could be different for other models but my car starts in 2nd unless I select first manually. 2019 5.0 SC SVA (Current)
I’m only assuming it’s 1st?
I think it's just supercharged models which start in 2nd |
| LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227
https://disco4.com/forum/pulling-away-seco...ght=Second
Thanks for the replies and information, been out this morning and she’s driven faultless. I’ll monitor the situation and look at doing the steel sump and separate filter conversion soon.
| Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567
That's normal for these cars. It knows you're talking about it so it's playing ball now! 2016 RRS SVR Estoril Blue
Very true |
