![]() | Home > Maintenance & Modifications > Cheap fix for GPS Aerial. |
| GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420
Thank you flack!
| ChrisKT Member Since: 02 Oct 2017 Location: Exeter Posts: 4
Hi all.
| wilchesth Member Since: 11 Mar 2018 Location: Falmouth Posts: 41
I had the same problem as everybody else with the GPS icon crossed out in red. I decided to buy an antenna as per Flack’s post and tried it first by connecting it directly to the back of the navigation unit and put the antenna by the window. Disconnected/connected all the cables first to give it a “reset”, did a location calibration and drove around for about half hour and the GPS icon is still crossed out in red and the location in the map is miles away from where the car is.
Just in case anybody has the same issues as me here is an update to my problem ^^^.
| Bustanut Member Since: 19 Nov 2017 Location: Nottingham Posts: 71
Does anyone know what unit to buy if you have problems with phone and DAB signal (interference when the door opens on the DAB and really poor crackly phone reception). I'm assuming its the same procedure just with a different type of aerial. Also after having a rummage around under the roof lining yesterday i couldnt get the connectors off. Does anyone have any pointers for this please.
| Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251
Can somebody post an up to date link to the cheap GPS unit to purchase. I’ve got code B1A89-11(6c) Satellite Antennae - general electrical failure - circuit short to ground. Found this thread via the search. 2006 2.7 TDV6 HSE in Cairns Blue. |
Try this one
| Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 321
Just done this job on mine, bought the cheapest sat nav aerial on eBay (£4) didn’t matter what connection as I reused mine. Very straight forward job.
Thanks |
I did this today having purchased an aerial from the link wilchesth posted having reduced the price to £4.99 posted!. Anyway followed the guide which was great but I took a couple of photo’s that may add to those already posted. The only issue I found with mine not mentioned is when I took the locking bit from the Fraka connection I couldn’t withdraw the cable. Looking down the barrel of the gun as such there was a little plastic lug, which I freed using an instrument screwdriver and bingo. It all works again and the only thing is all my securing clips (3) for the NSR boot panel were crushed, so I’ll have to order some of those yellow locating clips. Sorry for the poor photo’s but you get the idea. My base plate was rusty and the inside of the shark fin had condensation in it. All in all took me and hour and a bit but I am a bit James May on the speed front.
| Tomtun Member Since: 05 Oct 2021 Location: Aberdeenshire Posts: 2
Hi Flack,
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5117
If its just to test for a few days, put it in the front windscreen.
