Home > Maintenance & Modifications > Cheap fix for GPS Aerial.
Page 3 of 3 <123
GodivaNige
Thank you flack!
Just repaired my faulty GPS antenna for the princely sum of £5.75
You sir, are a steely eyed missile man
https://getyarn.io/yarn-clip/80ef1d66-60ee-4baf-8911-395cb90ad750
Post #543764 Wed Dec 20 2017 12:32pm
Pakolainen
Finland 2013 Range Rover Sport 3.0 TDV6 Autobiography Rimini Red
yup, same here, replaced mine in the summer. simple job. just now 6 months later working out i didn#t put enough & correct silicone in between shark finn and body.
but thanks. simple and very useful instructions 2019 RRS P400e Autobiography
2014 RRS 3.0 TDV6 HSE Dynamic
2006 RRS 2.7 TDV6 HSe
Alfa Romeo Guillietta 2.0 JTDM 2011
Mazda 3 1.6 2010
Subaru Impreza 2.0 WRX 2005
Post #543787 Wed Dec 20 2017 6:03pm
ChrisKT
United Kingdom 2007 Range Rover Sport TDV6 HSE Adriatic Blue
Hi all.
I have the same problem with my Sat Nav so i am going to order a new GPS antenna and i will let you know the outcome.
Post #547688 Sun Feb 04 2018 10:27pm
wilchesth
United Kingdom 2008 Range Rover Sport TDV6 SE Zermatt Silver
I had the same problem as everybody else with the GPS icon crossed out in red. I decided to buy an antenna as per Flack’s post and tried it first by connecting it directly to the back of the navigation unit and put the antenna by the window. Disconnected/connected all the cables first to give it a “reset”, did a location calibration and drove around for about half hour and the GPS icon is still crossed out in red and the location in the map is miles away from where the car is.
Am I the only one who has a genuine navigation unit faulty or was I so unlucky to buy a faulty or incompatible antenna of ebay? It was only £4.95. See link below
https://m.ebay.co.uk/itm/GPS-SAT-NAV-AERIA...SwAQBap0g4
By the way the model number of the navigation unit on my RRS is 8H42 10E887 AB.
Post #551900 Tue Mar 20 2018 11:17am
wilchesth
Just in case anybody has the same issues as me here is an update to my problem ^^^.
I bought another navigation unit and it still didn't work, it was still showing the GPS symbol crossed out. It turns out that if I remove the Fakra connector from the end of the new antenna and push the coaxial cable further it would work. Not sure why it wouldn't work with the Fakra connector ON, maybe the manufacturer of the antenna didn't assemble the connector properly?. Anyways, followed the instructions as per Flack's instructions and all is working again, but still with no Fakra connector at the end of the antenna. So now I have a fully working spare navigation unit which will have to go back to Ebay again. Happy days Very Happy . 2008 Range Rover Sport 2.7 SE Zermatt Silver.
Post #556081 Wed May 09 2018 3:50pm
Bustanut
Does anyone know what unit to buy if you have problems with phone and DAB signal (interference when the door opens on the DAB and really poor crackly phone reception). I'm assuming its the same procedure just with a different type of aerial. Also after having a rummage around under the roof lining yesterday i couldnt get the connectors off. Does anyone have any pointers for this please.
P.s. thanks to the original poster for taking the trouble to write this up.
Post #576341 Mon Mar 04 2019 12:28pm
Stevepd
Can somebody post an up to date link to the cheap GPS unit to purchase. I’ve got code B1A89-11(6c) Satellite Antennae - general electrical failure - circuit short to ground. Found this thread via the search. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #596683 Wed Mar 18 2020 4:13pm
wilchesth
Try this one
https://www.ebay.co.uk/itm/282845322242 2008 Range Rover Sport 2.7 SE Zermatt Silver.
Post #596684 Wed Mar 18 2020 4:29pm
Devon Z
England 2005 Range Rover Sport TDV6 HSE Java Black
Just done this job on mine, bought the cheapest sat nav aerial on eBay (£4) didn’t matter what connection as I reused mine. Very straight forward job.
Steve Steve
2005 2.7 TDV6 HSE, ongoing project.
1998 Volvo V70 R auto FWD, mothballed future project.
1999 BMW Z3 (owned from new) garage queen.
Post #596690 Wed Mar 18 2020 8:06pm
Stevepd
Thanks Thumbs Up 2006 2.7 TDV6 HSE in Cairns Blue.
Post #596692 Wed Mar 18 2020 9:20pm
Stevepd
I did this today having purchased an aerial from the link wilchesth posted having reduced the price to £4.99 posted!. Anyway followed the guide which was great but I took a couple of photo’s that may add to those already posted. The only issue I found with mine not mentioned is when I took the locking bit from the Fraka connection I couldn’t withdraw the cable. Looking down the barrel of the gun as such there was a little plastic lug, which I freed using an instrument screwdriver and bingo. It all works again and the only thing is all my securing clips (3) for the NSR boot panel were crushed, so I’ll have to order some of those yellow locating clips. Sorry for the poor photo’s but you get the idea. My base plate was rusty and the inside of the shark fin had condensation in it. All in all took me and hour and a bit but I am a bit James May on the speed front.
3BEFAA10-A417-406A-B78E-07BAD4984EDA by Stephen Priestley-Dean, on Flickr
38B01443-D8AA-4861-B079-7BAA7EF96078 by Stephen Priestley-Dean, on Flickr
7F0CE656-B782-4AAD-8A51-BBE7AA66BF0B by Stephen Priestley-Dean, on Flickr
444E9E13-4CBE-4C88-83BB-D48FE995D7BF by Stephen Priestley-Dean, on Flickr 2006 2.7 TDV6 HSE in Cairns Blue.
Post #597432 Mon Apr 06 2020 3:31pm
Tomtun
United Kingdom 2008 Range Rover Sport TDV8 Autobiography Java Black
Hi Flack,
Resurrecting one of your older posts, my question being, how easy was it to thread the new cable down to the unit (my dvd reader is under passenger seat).
I'd like to try this b4 buying a new sharkfin gps antenna.
Post #617907 Tue Oct 05 2021 3:09pm
If its just to test for a few days, put it in the front windscreen.
Thread it thru the passenger grab handle, then thru the rear one and down to under the seat
Post #617917 Tue Oct 05 2021 6:51pm
Page 3 of 3 <123
