![]() | Home > Technical > Speedo needle lighting |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4531 ![]() ![]() ![]() |
Officially, a new IPC
Godders Member Since: 26 Aug 2017 Location: Dordogne Posts: 155 ![]() ![]() ![]() |
Ive got the same problem on mine and watching with interest |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961 ![]() ![]() ![]() |
Appears to e a common fault,, not something for the average Diy buff to attempt. There are a few places that repair faulty instrument
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 208 ![]() ![]() ![]() |
I had my cluster replaced by RR, common fault. 2018 Telsa MS
Robs_2007_sport_hse Member Since: 12 Mar 2020 Location: Devon Posts: 5 ![]() ![]() ![]() |
Take the instrument cluster out and post it to these guys there fantastic
Now my reversing camera has decided it wants to work intermittently and takes the front and rear parking sensors out when it decides to turn itself off |
New instrument cluster fitted so normal service has now resumed |
Wenier Member Since: 09 Apr 2019 Location: Christchurch Posts: 15 ![]() ![]() ![]() |
If your good with soldering it is just surface mount LEDs on the circuit board failing. They are normally in pairs.
