![]() | Home > General > P400e tow bar |
Rusty Ranger Member Since: 03 Jan 2020 Location: East Sussex Posts: 61 ![]() ![]() |
No, the electrically deployable one isn't available because of the space taken by the battery. I believe that the tow bar is a dealer fit item, and that they use a removable two height unit which someone here said is made by Westfalia. |
Michael997 Member Since: 31 Jan 2006 Location: Worcestershire Posts: 244 ![]() ![]() |
Ok, still trying to move forward and get a tow bar on my Hybrid, unfortunately the dealers info from JLR says only a fixed one is available but I had a quick release one fitted by Land Rover to the hybrid I rejected in January so I know they do one, my dealer has agreed to order one from the part numbers used on my rejected RRS and see what arrives with them.
Thank you for that, the dealer has ordered one in to see if a quick release one turns up, if it does the next question to answer is with the Swan neck removed can the original lower bumper panel be reattached
