![]() | Home > Technical > Fault codes |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5091 ![]() ![]() ![]() |
You can ignore U codes |
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 316 ![]() ![]() ![]() |
Cheers Andy, the only other one of concern on the engine is cylinder 4 balance fuel trim at maximum, have researched this and possible things are air leak, fuel leak or dodgy injector? anything else I should look for?
you should read the injector offsets (at idle) and post them up |
UPDATE, this error has gone away |
This code has popped up again on my routine code check, cleared it and went for a long run yesterday and it’s not popped up again. I found out how to access live data on my Icarsoft code reader which is quite extensive these are the live offset readings on a cold engine and after about 15 minutes running.
