Home > General > Arc Pipe
adigorn
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
Quote:
tipped
yes
Quote:
take the body off
NO
Post #408229 Sun Jan 05 2014 7:00pm
Baz0195
England 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Paddi wrote:
'57 TDV8 HSE in Hertfordshire? Must help you then Laughing
Confusingly people often refer to the Dynamic Response system as 'ARC' (Active Roll Control).
Dynamic response is the patented system which uses hydraulically operated actuators on the anti-roll bars front and rear to counteract body roll when cornering.
In your post you said it is the ARC 'pipe' that needs replacing so possibly it is just part of the hydraulic system that is leaking and needs to be replaced but usually it is one of the actuators. Check with your garage which it is. Can you see any drops of fluid under the car where it is usually parked?
The actuators are notorious for developing leaks and they are not repairable so have to be replaced. They are Censored expensive at around �900 each and if it is the rear one the body has to be partially lifted from the chassis to fit it so quite a bit of labour. Plus, the system then has to be bled and recalibrated which is more work.
You could try just topping up the Dynamic response system reservoir with the correct fluid (only obtainable from Land Rover) and see if the red warning light goes out. If it is only a slight leak that might be a temporary fix. However; while the light is on - your body roll when cornering might be excessive and lead to loss of control so be careful driving!
If you are anywhere near Houghton Regis in Bedford give Bill at Autoland (01582 866680) a call and get them to give you a second opinion maybe?
Mine is leaking from the top of this pipe and was wondering if the pipe can be replaced, it’s on the front drivers side on my2010
Post #595005 Sun Feb 16 2020 4:52pm
Brit Plumber
See your other thread. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #595054 Mon Feb 17 2020 10:39am
gavcav
Leaking front ARC pipe.
Just been told i could have a possible bill of around £4000 to fix my car! I have a leak from a pipe going to the front ARC ACTUATOR ..location is shown in the attached photo. If there are problems replacing the pipes it can lead to other components in the system requiring replacement.
Apparently the pipes come as a kit and lead from the module to the actuator. I know this could lead to problems with the Module when trying to get the pipes out..My question is, there are pipe breaks (in-line connectors shown in photo) downstream of the module going to the actuator.. surely they are there to make it possible to replace the actuator supply pipes leading to the actuator without having to disturb the pipes going into the module?
I don't get why the pipes going into the module are being disturbed with it highly likely it will damage the module as well?
Post #613803 Thu May 20 2021 10:13am
Brit Plumber
Where’s that picture from? There are no couplers where they are shown, if you look at my photos you will see the couplers I fitted are in the same place (did they like my idea??).
So your existing pipes do not have those couplers. You could try to cut there and instal a new pipe, but they could be that corroded that they won’t seal.
Removing from the block isn’t to bad if you have some patience and a bit of penetrating oil. I popped of the plastic collars and used a trim pry tool to lever between the block and the swollen part of the pipe. They popped out quite easily.
https://www.amazon.co.uk/neilsen-CT2370-Do...&psc=1
This is what i did to prevent lifting the body.
Post #613806 Thu May 20 2021 11:30am
