![]() | Home > General > squealing brakes (is there a solution) |
drexal Member Since: 18 Dec 2019 Location: london Posts: 117 ![]() ![]() ![]() |
Hopefully this is the last thing i will need to ask for a while.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5102 ![]() ![]() ![]() |
All RRS1 S/C's came with six pot Brembo's could pay extra to have them red unless it's a A/B then standard, mine used to do this annoyed the hell out of me, never had to change discs but the only brake pads that I could find that cured this was EBC Redstuff even tried Brembo pads, unfortunately it would appear EBC no longer make these particular pads. The rear calipers will be TRW L/R never used Brembo's on the rear.
This was such a issue with the Brembo's L/R actualy brought out a Anti Squeal brake pad LR093886 don't know if it worked or not though.
I have the standard TRW calipers on mine but whenever I change pads, I always give everything a good clean down with brake cleaner, clean and regrease the slider pins and also smear some copperslip on the back of the pad (old school, yes, I know).
It certainly won't be a slider pin issue on the Brembo's because they don't have any, just retaining pins.
The OP hasn’t really been clear on the squeal but it could be any number of things. Does it happen when you lightly touch the brakes? Heavy touch? All the time? Applying the hand brake?
Your better off using ceramic brake grease rather than copper grease,alloy calipers don’t agree with copper grease neither does the abs system,this was mentioned by disco-Mikey in another post about brake pads.
I can only comment on my own experience, the squeal was at low speed with light braking couldn't hear it with the window up, brake a little harder and no noise, fitted the Redstuff pads about 15 months ago and around 8k since and not a squeak of any sort since. For got to mention it had new genuine L/R discs which have Brembo stamped on them, and genuine Brembo pads a little earlier and it never made a blind bit of difference until I fitted the EBC pads and it cured it completely.
Hi everyone, thanks for all this help and info, i'm going log everything everyone is saying. But the EBC sound like a great start.
Brembo fronts,with new discs & Hawk high performance low dust pads fitted this week so I cannot comment how good they are yet as I’ve only done about 30 mile
Can't actualy see a picture but if it is a 2012 RRS1 5.0L S/C they will be 6 pot Brembos. Just saw the picture yes they are Brembo's it's just that HSE's were not painted Red with Brembo on them unless specified as a option although standard fit on th A/B's.
Read this on the disco site
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 595 ![]() ![]() |
Do you only run the 30mm spacers on the rear Andy ? ![]() |
Yes,I tried them on the front but the wheels stuck out too far as the offset on these aftermarket alloys is 45 were as the original alloys are 49,someone on here with a svr put 25mm all round & posted a pic a few week ago & they looked fine but I’m not sure what the offset on those are,also my rims are 10j were as the originals are 9.5. Andy.
