Home > General > Head Rests TV |
Disco 4 headrests and I think late freelander headrests are the same but won’t have Autobiography on them. The RSE module will work but has the LR logo rather than RR but this can be configured with SDD if required. The 2012 on FFRR uses the same system but the headrests are different (but I think will still fit as posts are the same distance apart). Same I think for Evoque.
Sat Feb 15 2020 9:59am |
McFarTech Member Since: 13 Sep 2019 Location: Kent Posts: 126 |
Thanks mate. Will keep my eyes posted. ===========================================
Sat Feb 15 2020 11:35am |
Would l322 vogue fit? Also I assume a Range Rover sport 2009 l320 head rest won’t fit my 2013 l320? ===========================================
Sat Feb 15 2020 9:08pm |
I’m not sure if the L322 will fit, they may fit but not sure how they will look.
Sat Feb 15 2020 11:54pm |
Thanks mate. Its this that I had seen.
Sat Feb 15 2020 11:58pm |
I can see that the posts are different and will be a mare to change over. Also the screens are smaller and there’s a good chance won’t work with the later 2012 system. The expensive bit is the screens so your best off buying a ‘kit’ from a breaker. You need a module, 2 headrests with screen, looms, white fire receiver and volumetric alarm censor housing, white fire headphones, remote and if you want, you can put a dual view screen in for the front passenger. 2012 5.0 SC AB
Sun Feb 16 2020 9:47am |
This sounds expensive. Might need to rethink it ===========================================
Sun Feb 16 2020 10:40am |
What other options are there? I’m fine with a tablet style screen connected to the back of the head rest. However what I really want is for the screen to display what’s up front. Eg I pop a dvd in and it play in the back or input the tv on and it shows in the back.
Sun Feb 16 2020 12:41pm |
Check out incartech see what they have do quite a bit of gear for Land Rover |
Sun Feb 16 2020 1:16pm |
A kit from salvage would set you back approx. £700 with everything you need. Stripping out the interior including carpets takes a few hours but it does give you an excuse to do a deep clean.
Mon Feb 17 2020 10:43am |
£700 I don’t mind. Just got to find a salvage Range Rover sport. ===========================================
Mon Feb 17 2020 11:02am |
These are on ebay amongst othere may be of no use to you but a quick search
Mon Feb 17 2020 5:27pm |
Would these fit?
Sun Feb 23 2020 6:34pm |
. They sold before I got a chance to check. Ffs! ===========================================
Sun Feb 23 2020 6:43pm |
