![]() | Home > General > Head Rests TV |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5117 ![]() ![]() ![]() |
Apart from the stitching colour they look identical to the factory fitted RSE one's in my A/B.
Have you considered a Rosen aftermarket system they used to be the O.E. system for L/R. I had one of the their aftermarket systems in my previous sport and it was fine, headrest leather matched in really well, it was as long time ago, would imagine they are a lot nicer now and more O.E, probably larger screens now as well.
They are the same as the 2012 RRS but these won’t have the AB badging. The stitching may or may not match too. Big problem here is that they are £250 each without screens, and these can cost a LOT of money! You also would need the wiring for each seat, from seat to module, the module, wiring from module to head unit, white fire IR unit, remote control, remote control armrest and charging unit and headphones (latter 4 aren’t needed for the system to work). Just keep an eye open for a kit or ring around breakers. The cream leather seats that were sold were no good as they were for the earlier system. 2019 5.0 SC SVA (Current) 2012 5.0 SC AB. Sadly written off by a campervan 23 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
