Home > Technical > non starting?
hairy
United Kingdom 2009 Range Rover Sport TDV8 HSE Zambezi Silver
non starting?
2009 sport, i get in turn the key and click... try a few times with the same result, eventually it will start no problem, Ive checked the battery all good, dont believe it is the starter? anyone got any ideas what to start looking for the problem?
Post #594525 Fri Feb 07 2020 9:03pm
Try swapping the relay marked SM in the box Under the bonnet
Post #594527 Fri Feb 07 2020 9:31pm
hairy
thanks will give it try in the morning.
Post #594531 Fri Feb 07 2020 11:04pm
hairy
well swapped the relay this morning and it made no difference, anyone else got any ideas?
Post #594535 Sat Feb 08 2020 9:40am
H
England 2007 Range Rover Sport TDV6 HSE Santorini Black
Starting
Do you let the glow plug light go out, I had this problem regards chris
Post #594541 Sat Feb 08 2020 10:44am
hairy
yeah I always wait until the light goes out, but this happens hot or cold so cant be the glow plugs.
I swapped replay SM this morning and it made no difference I am now suspecting a sticky solenoid but not sure?
Post #594544 Sat Feb 08 2020 12:03pm
check the battery connections.
where the earth cable bolts to the inner wing. Check it isn't loose. (battery removal required)
Then yes, probably a new starter required
Post #594549 Sat Feb 08 2020 4:19pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Re: non starting?
How did you check the battery, voltage under load or off load?
If not already done, have someone check the battery volts while you try to start it, it should hopefully stay above 9.6V - use a meter direct across the battery terminals. Just checking battery volts without load tells very little. 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #594553 Sat Feb 08 2020 5:19pm
hairy
checked battery both under load and no load, all ok. I will check the connection on the wing under the battery today weather permitting.
Thanks for your advise so far.
Post #594577 Sun Feb 09 2020 8:09am
hairy
removed the battery and checked the connection and all was ok, so I guess now the only thing left is the starter motor?
Post #594600 Sun Feb 09 2020 7:54pm
Disco_Mikey
Or, have the starting circuit checked, before throwing parts at it Thumbs Up
Post #594605 Sun Feb 09 2020 9:24pm
hairy
sorted
UPdate****well finally got under the car and the starter is dead... replaced with new and all ok now.
Post #596486 Sat Mar 14 2020 5:24pm
Robs_2007_sport_hse
Some times its a bad connection on the starter motor just removing the contacts and cleaning can often cure it.. Bet you had fun changing that starter motor Whistle
Post #596510 Sun Mar 15 2020 9:03am
hairy
replacing starter
it was an absolute pain in the butt... but changed now and all ok, hopefully I dont have to do that again soon!
Very Happy
Post #596512 Sun Mar 15 2020 9:56am
