Home > Faults & Fixes > could this be an earth issue?
PC76
Evening all,
When I have been looking at the fault codes using my IID tool I have recently been receiving the below (that's the first time they appeared), not had any ride issues etc. but wondering if I may have a loose / bad earth? they same up again this week so just want to get it sorted before it does actually start to cause problems....
C0063-14 (ACool Yaw rate sensor - General electrical failure - circuit short to ground or open
( on 23-11-2019 23:03:39 at 213216 km )
U0123-00 (ECool Lost communication with yaw rate sensor module
U0126-00 (ACool Lost communication with steering angle sensor module
( on 23-11-2019 19:49:34 at 213187 km )
U0132-00 (2Cool Lost communication with ride level control module
( on 25-11-2019 11:35:23 at 213565 km )
Post #593857 Sun Jan 26 2020 7:36pm
knwatkins
Could be. It could also just be blip. They all appeared at the same exact date and time back in November.
Does the date and time coincide with any work you were doing on the vehicle? It could be a connector that was unplugged.
I would clear the codes and monitor. Kev
Post #593861 Sun Jan 26 2020 8:15pm
PC76
Hi Kev,
Not done any work other than brakes / parking brake. it's happened at least three times since.
Wondered if it could also be the brake switch, but that appears to be working fine (light works when pressed without any visible flickering)
Post #593864 Sun Jan 26 2020 8:47pm
knwatkins
Strange. Sorry, I just noticed the bottom two occured at different times.
Any correlation between the dates and times when it's occuring? Eg. car parked at a particular angle, adverse weather etc.
Sorry, clutching at straws but just interested! Kev
Post #593869 Sun Jan 26 2020 11:43pm
PC76
I have been completing long drives since mid October up until recently running up and down to remote northern parts of Scotland, so some fast roads and general cruise control and minor off road tracks (farms & forrest).
Post #593922 Mon Jan 27 2020 11:26pm
Wcox97
England 2010 Range Rover Sport TDV8 HSE Galway Green
Bump
Hi there, sorry to awake an old thread ... but was this issue ever solved?
Post #613166 Sun May 02 2021 10:29am
