Home > Technical > "Plip plip" refusal to lock - can you interrogate |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
Gah, short subject line box..
Wed Jan 22 2020 12:54pm |
Good tip! I'll lock/unlock a few times and pay attention to the handles I had the rear passenger lock assembly replaced last year at the MOT (it was failing to unlock) so it could be one of the others following suit - or of course, a faulty replacement. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Wed Jan 22 2020 3:08pm |
It did it last night - looking through the doors it doesn't look like any of the door locks are attempting to move.. of course, I forgot to look at the dashboard to see if the speedo cluster told me anything at the same time 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Fri Jan 24 2020 10:46am |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1847 |
My 12MY doesn’t work like that, if it detects an issue it doesn’t even try and lock the doors, it will just peep peep as if it’s a door ajar rather than a lock. If on the odd occasion mine does it, I just open and close the doors that have been used and it’s normally my driver door. 2012 5.0 SC AB
Fri Jan 24 2020 12:03pm |
Yeah - on the odd occasion it hasn't locked on the second press, that's what I've taken to doing.. not always the same door, but opening & closing 'a' door seems to cure it. Of course, it could be a sticky switch on any other door and maybe the vibration from shutting the door nudges the switch.
Fri Jan 24 2020 1:08pm |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 575 |
usually the bonnet catch is the culprit on an L320 |
Fri Jan 24 2020 6:45pm |
