![]() | Home > Technical > What's this connector |
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 ![]() ![]() |
Transit relay connector, not used once the car has gone through the PDI |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 932 ![]() ![]() |
Thanks for that |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1559 ![]() ![]() ![]() |
Now that would be good! |
No that connecter is called the AA saves on mileage as well 👍😉 2008 G4 RRSport TDV8 current
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 413 ![]() ![]() |
out of interest what happens if its connected back up? If a jobs worth doing, get a someone who knows what they are doing to do it!
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5118 ![]() ![]() ![]() |
The item it is connects to before delivery isn't present. |
so once its been disconnected the connection is broken and cant be re-used If a jobs worth doing, get a someone who knows what they are doing to do it!
As it's used to limit some of the electrical functions during delivery/storage to conserve battery power not sure what else it could be used for if any, as the relay is physically removed by the dealer prior to delivering the vehicle to the customer, not sure you could even obtain a replacement relay if you wanted to store your vehicle for a period of time.
Yeah makes sense I guess, just wondered more than anything else really I gues it just shut donw all the things that drain the battery that wouldnt be needed like alarm etc...
As with many things JLR, there are several (incompatible) variants of transit relay.
Easiest solution, just buy a Ctek smart charger assuming you have a power supply where vehicle stored.
