Home > Technical > Battery clamp screw L494
Lindab
Does anyone know the size of the battery +ve clamp screw on the L494. I have decided to put a permanent feed fag lighter socket in the boot to run my Ctek. I have a comfort connector under the front grille, but by putting one in the boot it allows me to hook it up no matter which way the car is in the garage (some might say I too much time on my hands Very Happy )
Anyway would like to get the screw size before removing the full size spare with that well engineered lifting device supplied Censored then I would make sure I have the correct electrical eyelet
Post #593249 Mon Jan 13 2020 3:01pm
Red Arrow
10mm Thumbs Up
Post #593256 Mon Jan 13 2020 5:35pm
Lindab
Thanks for that, Thumbs Up now to get that Censored wheel out Evil or Very Mad
Post #593260 Mon Jan 13 2020 7:33pm
Not sure it helps in any way but the nut shown here (HN1) is 8mm thread diameter. Is that 10mm thread dia. or nut size which would be 6mm thread dia.
Post #593266 Mon Jan 13 2020 10:22pm
Lindab
After much Censored again, getting the spare wheel removed. The battery +ve is 10mm nut & M6 thread. Job done, now have permanent fag lighter socket in the boot Very Happy . Mounted it in the recessed section on right hand drivers side
Post #593418 Fri Jan 17 2020 3:13pm
