Home > Technical > Battery clamp screw L494 |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 576 |
10mm |
Mon Jan 13 2020 5:35pm |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 869 |
Thanks for that, now to get that wheel out |
Mon Jan 13 2020 7:33pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4847 |
Not sure it helps in any way but the nut shown here (HN1) is 8mm thread diameter. Is that 10mm thread dia. or nut size which would be 6mm thread dia.
Mon Jan 13 2020 10:22pm |
After much again, getting the spare wheel removed. The battery +ve is 10mm nut & M6 thread. Job done, now have permanent fag lighter socket in the boot . Mounted it in the recessed section on right hand drivers side
Fri Jan 17 2020 3:13pm |
