![]() | Home > Maintenance & Modifications > Tdv6 2.7 inlet manifolds replacement |
Fluff006 Member Since: 03 Nov 2019 Location: Dorset Posts: 14 ![]() ![]() ![]() |
What £70 ish from land rover or eBay? It’s the stupid clips that put me off too. In my experience if you can leave those types of clips alone then do. You talk like you’ve experienced a leaky pipe? It’s only a shave of the corner of the leak off nipple that’s missing but the drip is from the pipe inlet. All pipes are tight and if I hold the leak off in a certain place it will slow the drip down. If you see a link please send it. I’ve looked everywhere. Thanks. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5134 ![]() ![]() ![]() |
https://rover.ebay.com/rover/0/0/0?mpre=ht...2762802446
yes I had a similar problem where the end broke off and I had to replace it, to prevent leaking |
So drove it for the first time today. About 50 meters and felt like it put the front passenger side brake on. Then said edc fault. Special functions not available. And lowered the suspension. Only when I drive it. On start up it’s fine. |
