Home > Maintenance & Modifications > Tdv6 2.7 inlet manifolds replacement
Leak off pipes are annoying when they break.
Sometimes you can get an individual one off eBay, but frequently the wrong item turns up.
Don’t assumme they are all the same. Look carefully and even then....
A complete pipe is prob £70 ish.
Post #593221 Sun Jan 12 2020 7:22pm
Fluff006
England 2008 Range Rover Sport TDV6 HSE Santorini Black
What £70 ish from land rover or eBay? It’s the stupid clips that put me off too. In my experience if you can leave those types of clips alone then do. You talk like you’ve experienced a leaky pipe? It’s only a shave of the corner of the leak off nipple that’s missing but the drip is from the pipe inlet. All pipes are tight and if I hold the leak off in a certain place it will slow the drip down. If you see a link please send it. I’ve looked everywhere. Thanks.
Post #593231 Sun Jan 12 2020 11:20pm
https://rover.ebay.com/rover/0/0/0?mpre=ht...2762802446
https://rover.ebay.com/rover/0/0/0?mpre=ht...3298806819
Search 2.7 leak off pipe on eBay.
Jaguar ones should fit too
Post #593232 Sun Jan 12 2020 11:24pm
yes I had a similar problem where the end broke off and I had to replace it, to prevent leaking
Post #593246 Mon Jan 13 2020 1:16pm
Fluff006
So drove it for the first time today. About 50 meters and felt like it put the front passenger side brake on. Then said edc fault. Special functions not available. And lowered the suspension. Only when I drive it. On start up it’s fine.
Post #593490 Sat Jan 18 2020 7:35pm
