Home > Technical > RR sport - CRUISE CONTROL issue
Lindab
Try disconnecting the battery for half an hour. May be a software glitch & needs a reset. Just a thought Thumbs Up
Post #592381 Thu Dec 26 2019 8:19pm
nil07
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bonatti Grey
Might try that as mines still saying that.
Is that an easy thing to do? For clueless car ppl like me Rolling with laughter N
E46 M3
X6
2015 RRS HSE dynamic
2018 RRS Autobiography
2019 SVR
Post #592385 Thu Dec 26 2019 10:38pm
Lindab
The hardest thing is if you have a full size spare is lifting it out of the way as its awkward to say the least. They give you a Heath Robinson strap which must have been designed by a five year old or Heath Robinson Rolling with laughter
Anyway when its removed, lift a flap which covers the battery then disconnect neg terminal first then pos terminal. Here is a video of someone doing it
Post #592398 Fri Dec 27 2019 1:19pm
nil07
Got the following error code
C1A67 Radar sensor
Adjustment faulty
Anyone else had this ? N
E46 M3
X6
2019 SVR
Post #592480 Sat Dec 28 2019 10:47pm
nil07
Had the LR technician do,e out to me
Couldn’t reset and said radar cruise needs adjusting / calibrating .
Phone up LR grange Hatfield to ask when is next and they say Jan 21st.
So I ask whether it can be done while I wait ..... and I’m still waiting an answer Rolling with laughter
I:emailed them 4 hours ago.... maybe they still hungover 😵 N
E46 M3
X6
2019 SVR
Post #592638 Thu Jan 02 2020 3:08pm
nil07
car in grange Barnet and have been told there is a bracket which holds the radar behind the bumper.
Apparently it is buckled and can be caused by small reformable bumper impacts .
Not covered under warranty — £581 N
E46 M3
X6
2019 SVR
Post #595249 Thu Feb 20 2020 6:10pm
nil07
They have now said they have fixed a bracket and there is no external damage to the radar unit....
So that may be claimable through warranty
??? N
E46 M3
X6
2019 SVR
Post #595332 Fri Feb 21 2020 6:17pm
Eaters
Wowa! Have I got this right? They are saying that:
- The bracket was the problem! Deformed
- It was caused by numerous small bumper impacts which presumably was either you hitting something a lot, or someone hitting you a lot
- Such damage may be covered under warranty?????
Curiouser and curiouser Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #595336 Fri Feb 21 2020 7:29pm
nil07
Yes don’t quite get it ....
Which makes me think that the bracket they will charge me for and the new radar free ?
Will keep u posted .... N
E46 M3
X6
2019 SVR
Post #595347 Fri Feb 21 2020 11:05pm
Not sure if it is the same bracket on a SVR as other L494's but that is a £15.00 bracket. The Sensor is around £1200.00 so if they want to charge £581.00 that is either a very cheap repair or more likely with L/R a very expensive £15.00 bracket.
Post #595349 Fri Feb 21 2020 11:31pm
nil07
Interesting ..... N
E46 M3
X6
2019 SVR
Post #595351 Sat Feb 22 2020 12:12am
nil07
Price could include bracket plus taking bumper on and off etc.... I will await further info .... N
E46 M3
X6
2019 SVR
Post #595352 Sat Feb 22 2020 12:17am
Just seems like a awful lot of money to me just to replace the bracket, although will admit I don't know how much work is involved in removing and refitting the bumper and align the sensor. If it is anything like the previous model it takes about a hour or so to change the bumper.
Post #595353 Sat Feb 22 2020 1:27am
nil07
So bracket damaged - but radar still didn’t work . So claimed radar under warranty. So damaged bracket covered .
Very odd
But I have no complaints as FOC. N
E46 M3
X6
2019 SVR
Post #595865 Sun Mar 01 2020 7:47pm
