Home > In Car Electronics > Another little project complete
knwatkins
As we know, the RRS and Disco 3/4 are quite heavy on the battery. Due to the fact I have a new battery that I want to look after coupled with my regular use of heated seats, heated steering wheel, timed climate and remote pre-heat pretty much most days, I thought I should give the battery a helping hand.
I appreciate many owners use the towing electrics to plug in a charger, but this was not ideal for me due to the following reasons:
a) The charger is left outside where any little oik could come along and nab it
b) The towing cover requires removal/refitting every time which is a bit of a faff when you just need to get in and go
c) I only have single socket, 7 pin aftermarket electrics on mine anyway (ie. no permanent live)
So, I decided to mount the charger internally to the vehicle.
A little IEC60320 C14 socket on the downward facing face of the rear bumper with a hinged cover to protect it against the elements...
Wiring routed through the grommet behind the nearside rear light...
The 12V side is connected to the towing electrics connector behind the nearside rear quarter panel interior panel. Blue/pink is permanent 12V to the battery and white is ground. Crimped spade connectors fit very well into the connector. Afterwards, I taped it all up to be 100% safe and secure.
And the finished job...
I hope this helps someone who may want to do something similar. Kev
Post #592162 Sat Dec 21 2019 2:02pm
riverblanche
Not seen it done that way before
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #592164 Sat Dec 21 2019 2:14pm
DrRob
Genius Bow down Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #592166 Sat Dec 21 2019 2:32pm
aaronjb
Be honest Kev, you were just jealous of the folks in this thread, with their plug-in 400e's, weren't you? Mr. Green Mr. Green
Very nice neat & tidy job, though! 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #592173 Sat Dec 21 2019 3:21pm
Stevepd
See what happens when you have no faults to consider Twisted Evil
Great idea and execution though 2006 2.7 TDV6 HSE in Cairns Blue.
Post #592175 Sat Dec 21 2019 3:46pm
knwatkins
I'm glad you guys approve Cool
I was intending on just posting the last picture in a 'First electric L320' thread, but I thought everyone would immediately see through it! Whistle Kev
Post #592181 Sat Dec 21 2019 7:42pm
Eaters
Nice piece of work that Thumbs Up Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #592196 Sun Dec 22 2019 10:34am
Nice project, well done. Thumbs Up
One tiny thing comes to mind - the flap of the socket under the bumper might be forced open by airflow as the leading edge of the flap is facing upstream - or is the spring good and strong? Be annoying for the socket to get filled with crud. 2012 SDV6 - it's missing a couple of cylinders
Post #592198 Sun Dec 22 2019 11:38am
HughN
Wales
Nice work, Kev. Thumbs Up
Don't forget a high-viz warning sign for the steering-wheel so you remember to unplug the lead before driving off. Laughing
Post #592199 Sun Dec 22 2019 11:38am
knwatkins
Cheers guys.
The spring is more than strong enough to keep it closed. Although, I will check it every now and again. Providing it stays closed and the spring doesn't fail, I think the terminals should stay good, but I'll spray a little bit of light oil in there anyway to add a bit of extra protection.
Yes that sign would be a good idea Hugh. I know that's what Gary, gstuart, over on the Disco forum does when he has his CTEK plugged in on the towing point. I purposely used a bright orange cable and I will have to walk over it when approaching the vehicle. Fingers crossed, this will be enough.
What I may do though is just wire up a little buzzer inside the car so that when the car is unlocked and mains is plugged in, it beeps to remind you. I suppose I could rig up a relay to prevent the car being started when the charger is plugged in, but that's probably a step too far for now. Kev
Post #592202 Sun Dec 22 2019 12:10pm
OvalAutos
Decent job Kev. Thumbs Up Joe
Post #592219 Sun Dec 22 2019 2:54pm
flydive
Nice job.
Two small points.
Make sure the power cable does not chafe anywhere, you do not want 220v running through the car body.
Maybe you could have put the CTEK on the right side of the boot, inside the removable flap, it would have been more protected when loading the boot.
But, as said, nice job Thumbs Up '08 RRS TDV8
Post #592254 Mon Dec 23 2019 10:02am
aaronjb
A bit of split conduit would work well to prevent chafing - https://www.12voltplanet.co.uk/split-convo...-tube.html (I should have bought shares in this stuff, there's miles of it in the kit car Laughing ) 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #592256 Mon Dec 23 2019 10:20am
knwatkins
No chafing will occur because the cable follows the existing route of the towing electrics. All 230V cabling is also double insulated and where the cable enters the car, this is via a rubber grommet.
I've ordered the bits for the warning alarm to prevent against driving off with the cable connected. I should have this installed within the next week or two. I'll do a YouTube video demo for you guys when it's installed. Kev
Post #592283 Mon Dec 23 2019 3:16pm
knwatkins
Sorry it's taken a while, I completely forgot to do a video to demonstrate the alarm when the power is plugged in. I've had this installed for the last 3 months and it's all still running great.
Here's a video of the alarm to reduce the risk of driving off with the power cable plugged in...
 Kev
Post #597057 Thu Mar 26 2020 11:06pm
