Home > Technical > Lower Front Arms |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4835 |
Just replaced lower front suspension arms fitted with poly bushes, however finding the ride a little to harsh for my likening so going to do it all again with new arms fitted the Meyle solid bushes and see how we get on with those, at least bolts will come out easy this time to be fair though only had to cut one bolt to remove original arm so not to bad.
Tue Dec 17 2019 8:31am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4332 |
If you insist on Polys, fit Superpro
Tue Dec 17 2019 9:35pm |
Thanks Mikey, not sure what make of bush the poly one's are they were fitted to complete arms from A/F, have now ordered a set with the Meyle bushes fitted from them. As have a spare set of arms may well fit Superpro bushes to them as spares or sell them on, just one genuine L/R Hydra bush down here alone is £125.00 as based on mileage I do these days probably never need them.
Tue Dec 17 2019 9:58pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1240 |
I found this the other day
Wed Dec 18 2019 5:29pm |
Just swapped the front lower arms again with one's fitted with Meyle HD bushes and have to say found them a much smoother ride than the poly bush ones I previously fitted which were a little to harsh for me, so personally have to say I prefer the rubber bushes. Now just got to find someone down here who knows how to do the alignment correctly, not to many seem to have the Hunter equipment either.
Tue Jan 14 2020 10:39am |
Thanks for posting that, it was highly informative |
Tue Jan 14 2020 1:54pm |
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 |
Col did you only replace the lower front arms? Or did you do the whole lot. Do Meyle do rear arms also ? Mine is a 2012 RRS |
Sat Apr 04 2020 4:29pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
I have the Meyle Heavy Duty front lower arms from AF on mine.
Sat Apr 04 2020 9:09pm |
Yeah, only replaced the front arms with the Meyle H/D bushes fitted as they were the only one's needed, certainly seem good quality and fair price, personal preference but wouldn't recommend the polybush ones as bit to harsh for me. Like Kevin said I don't think A/F list the other arms/bushes as H/D.
Sun Apr 05 2020 9:51am |
