![]() | Home > Technical > Lower Front Arms |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5151 ![]() ![]() ![]() |
Just replaced lower front suspension arms fitted with poly bushes, however finding the ride a little to harsh for my likening so going to do it all again with new arms fitted the Meyle solid bushes and see how we get on with those, at least bolts will come out easy this time |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4531 ![]() ![]() ![]() |
If you insist on Polys, fit Superpro |
Thanks Mikey, |
I found this the other day
Just swapped the front lower arms again with one's fitted with Meyle HD bushes and have to say found them a much smoother ride than the poly bush ones I previously fitted which were a little to harsh for me, so personally have to say I prefer the rubber bushes. Now just got to find someone down here who knows how to do the alignment correctly, not to many seem to have the Hunter equipment either.
Thanks for posting that, it was highly informative ![]() |
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 ![]() ![]() |
Col did you only replace the lower front arms? Or did you do the whole lot. Do Meyle do rear arms also ? Mine is a 2012 RRS |
I have the Meyle Heavy Duty front lower arms from AF on mine.
Yeah, only replaced the front arms with the Meyle H/D bushes fitted as they were the only one's needed, certainly seem good quality and fair price, personal preference but wouldn't recommend the polybush ones as bit to harsh for me. Like Kevin said I don't think A/F list the other arms/bushes as H/D.
