![]() | Home > General > Dynamic Response |
idi Member Since: 19 Nov 2019 Location: England Posts: 134 ![]() ![]() |
I have a 3.0 V6 in my 2010. How do I know if it is fitted with Dynamic Response? |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
there are two options for susspension.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9068 ![]() ![]() ![]() |
Dynamic Response and Active Corner Enhancement (ACE) are the same thing - the hydraulic anti roll bars. ACE was the old name used on earlier Discos etc.
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
And also disables cruise control, for reasons that are beyond me! (I did an entire commute wondering thinking cruise was broken |
The dynamic programme is intended for times when one is driving a fast, twisty road. Why would you want to use cruise control in such a circumstance? 2012 SDV6 - it's missing a couple of cylinders
Silverstone Member Since: 04 Sep 2014 Location: Towcester Posts: 184 ![]() ![]() ![]() |
I read the above posted and just checked driving to work that adaptive cruise control works in Dynamic Response and it does. This is useful as unless I am in town (with speed bumps etc) I set mine to Dynamic Response as soon as I start the engine. There is no replacement for displacement - W O Bentley
You set it to dynamic mode, not Dynamic Response. The former is the Terrain Response programme, the latter is hydraulic hardware under the vehicle. |
Sorry - stand corrected |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 ![]() ![]() |
It does apparently change the fuel map as well in dynamic so you may not be doing yourself many favors by doing this (that said with a V8 its probably not that much of a difference) 2012 SDV6 HSE (technically its hers) 2000 D2 TD5 - definitely mine 2005 D3 V8 Metalian Camper trailer for adventures |
The difference will be that it'll use lots and lots of petrol rather than just lots of petrol |
abiopete Member Since: 27 Feb 2020 Location: Manchester, UK Posts: 169 ![]() ![]() ![]() |
Hi whats your reasoning for this? I'm relatively new to the RR world, never use the special programs.. Cheers, PEte. L494 3.0L SDV6 Autobiography in Chile Red (Current) L320 3.0L SDV6 Autobiography in Baltic Blue (RIP 29/03/2021 insurance total loss) |
