Home > General > Dynamic Response
idi
Dynamic Response
I have a 3.0 V6 in my 2010. How do I know if it is fitted with Dynamic Response?
Post #591645 Mon Dec 09 2019 10:21am
Camelrock
Check under the bonnet for res next to the rad with a yellow cap looks the same as the pas res but with different icon on the cap, or look under the car on the drivers side the valve block is mounted on the outside chassis rail 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #591649 Mon Dec 09 2019 11:26am
PC76
there are two options for susspension.
1) Adaptive Damping (not Dynamic Response) (Edited)
2) Active Corner Enhancement
I have the ACC which has the yellow filler cap front left between the radiator and hte headlamp. but i do not have the DR.
use this link to see diferences in the parts for each. https://www.advancedfactors.co.uk/steering--suspension-22-c.asp
Post #591804 Thu Dec 12 2019 2:03pm
Dynamic Response and Active Corner Enhancement (ACE) are the same thing - the hydraulic anti roll bars. ACE was the old name used on earlier Discos etc.
The dynamic programme in Terrain Response is a different thing altogether, being a programme that changes various car settings (including the suspension) to make for a more sporty drive. 2012 SDV6 - it's missing a couple of cylinders
Post #591811 Thu Dec 12 2019 5:43pm
aaronjb
And also disables cruise control, for reasons that are beyond me! (I did an entire commute wondering thinking cruise was broken Laughing ) 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #591821 Thu Dec 12 2019 10:43pm
The dynamic programme is intended for times when one is driving a fast, twisty road. Why would you want to use cruise control in such a circumstance? 2012 SDV6 - it's missing a couple of cylinders
Post #591825 Fri Dec 13 2019 2:07am
Silverstone
United Kingdom 2012 Range Rover Sport Supercharged HSE Baltic Blue
I read the above posted and just checked driving to work that adaptive cruise control works in Dynamic Response and it does. This is useful as unless I am in town (with speed bumps etc) I set mine to Dynamic Response as soon as I start the engine. There is no replacement for displacement - W O Bentley
MY2013 5.0 Supercharged HSE L320
Post #591830 Fri Dec 13 2019 8:41am
You set it to dynamic mode, not Dynamic Response. The former is the Terrain Response programme, the latter is hydraulic hardware under the vehicle. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #591834 Fri Dec 13 2019 10:06am
Silverstone
Sorry - stand corrected Very Happy There is no replacement for displacement - W O Bentley
Post #591838 Fri Dec 13 2019 3:15pm
Duc750
It does apparently change the fuel map as well in dynamic so you may not be doing yourself many favors by doing this (that said with a V8 its probably not that much of a difference) 2012 SDV6 HSE (technically its hers)
2000 D2 TD5 - definitely mine
2005 D3 V8
Metalian Camper trailer for adventures
Post #591846 Fri Dec 13 2019 10:40pm
Silverstone
The difference will be that it'll use lots and lots of petrol rather than just lots of petrol Laughing There is no replacement for displacement - W O Bentley
Post #591848 Fri Dec 13 2019 11:28pm
abiopete
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Hi whats your reasoning for this? I'm relatively new to the RR world, never use the special programs..
Cheers,
PEte. L494 3.0L SDV6 Autobiography in Chile Red (Current)
L320 3.0L SDV6 Autobiography in Baltic Blue (RIP 29/03/2021 insurance total loss)
Post #602361 Tue Jul 28 2020 10:42am
