![]() | Home > Maintenance & Modifications > Uncapped aftermarket wheel nuts |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1200 ![]() ![]() ![]() |
another UK supplier: https://www.ebay.co.uk/itm/Land-Rover-Disc...2767864380
-- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport Supercharged V8 HSE Dynamic ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2015 ![]() ![]() |
I want silver non capped |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 932 ![]() ![]() |
Dr Rob, Out of stock but worth a try to see if they are getting more
Boatman Member Since: 20 Dec 2018 Location: SOUTHAMPTON Posts: 14 ![]() ![]() ![]() |
Have just received a set from 'The alloy hub'. Solid and stainless for £64. Brilliant! https://www.alloyhub.com/ MY2006 / 2.7TDV6 HSE / CAIRNS BLUE |
^ yes, I am tending to also go for the Alloy Hub ones, they look like a quality product.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() * GONE. 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8 * GONE: 2011 4.4 TDV8 Full Fat. Amazing piece of kit. * Current. 1974 Lightweight 2.25L petrol. Old skool I use www.glenrands.co.uk Great independent * 1949 80" in family since 1975 |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
I guess that would be these? https://www.ebay.co.uk/itm/Set-of-16-x-M14...2127198254
Thanks for clarifying |
I've heard that some of solid ones go rusty after a while (the silver ones). Please let us know how you guys get on after a period of time with them.
These just arrived, will be putting them on later when the heat has died down.
Finally fitted them, I think they look great. And most importantly, they are solid nuts - already struggled with one of the capped ones, so just-in-time!
6 months later, and these are starting to rust already.
That's really disappointing, naks. I suppose the only thing you can do is keep touching them up to keep the rust at bay.
Yep, disappointing.
