Home > Maintenance & Modifications > EGR blanking MoT
Ians63
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
EGR blanking MoT
Would somebody be able to confirm the very latest MoT rules and regs for EGR blanking. My search seems to give varying answers. Looking at fitting blanking kit and getting through it’s test in an ideal world. RRS 2006
2.7 TDV6
Zermatt Silver
Post #591653 Mon Dec 09 2019 12:06pm
Tyrefitter
Don't worry about it,im a mot tester & you can only test what you can see so as long as it passes the emissions test your fine.At the end of the day we arnt & cannot remove the egr to see if its been blanked off. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #591660 Mon Dec 09 2019 3:28pm
Oldandconfused
As far as I know, with yours being pre-2007, it doesn't need a software patch so straightforward; remove pipes, blanking plates on, replace pipes and remove the butterfly valve. People didn't used to replace the pipes, but with it being an MOT fail just replacing them will fool a cursory look. Of course, as per previous post, the tester can't remove the engine cover to check if everything is there but it's not much effort to make sure.
Post #591690 Mon Dec 09 2019 11:02pm
Eskimo
I've blanked them on my 2006 with a kit from Ebay. No issues at MOT, I did replace the original pipe work though so still looks like they're fitted. 2006 RRS HSE 2.7 TDV6 (The Baby one as I keep being told)
1999 Discovery 4.0 V8 (Gone but not forgotten)
1997 Range Rover 3.5 V8 (Long gone now)
1966 Series II SWB with RR 3.5 V8 (Never finished, now sold)
Post #592374 Thu Dec 26 2019 5:26pm
DrRob
As above, blanking plate and replace the pipes so it looks stock Thumbs Up * Current: 2024 D350 Defender 90 on coils!
* Current: 1974 Lightweight 2.25L petrol. Old skool
* GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8
I use www.glenrands.co.uk Great independent specialist!
Post #592375 Thu Dec 26 2019 5:58pm
Disco_Mikey
Strictly speaking, it's an MOT fail, as an emissions device has been altered
However, unless the pipes have been removed, it's almost impossible to detect if the blanking has been done Thumbs Up
Post #592377 Thu Dec 26 2019 6:43pm
BigBerthaTheRRS
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
I can see how it is easy to do this and fit the pipes over the plates at the bottom. But at the top...do the pipes fit over the blanking plates or do you not put any plates in the top and still have the plastic housing 'open' to the pipe so to say, just making sure its all sealed at the bottom end with an extra gasket?
Post #620006 Wed Dec 15 2021 4:25pm
