![]() | Home > Maintenance & Modifications > Roxanne. You don't have to put on that red [battery] light.& |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 ![]() ![]() |
Genuinely no expert here but in short it sounds very much like you have no power - that rather rules out the power manageent system in my book 2012 SDV6 HSE (technically its hers)
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1899 ![]() ![]() |
Are you sure your battery recovered properly?
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
As above, dodgy battery? A faulty battery is a fairly reliable way to take out an alternator, and we say 0.8V per cell can be 'the point of no recovery', so your 5.4V is under the 9.6V minimum (assuming standard wet cell). Your battery paperwork will have a recommended charge rate which will be in the region of 10%, so charging at anything less wouldn't help, regardless of what it says on the fancy charger box (thinking 5A CTek etc.). Personally, knowing the cost of Landrover parts I'd have played safe and repurposed that battery. Good luck 13MY Range Rover Sport Autobiography SDV6 - mine
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 ![]() ![]() |
It might be prudent to change battery and alternator then. The 'old' battery can run an inverter. In fact, if I connect the charger to the inverter, I'll have unlimited free energy! |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5074 ![]() ![]() ![]() |
Lesson for everyone.
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
If you were seeing 17V out of the alternator (and voltage rising with engine speed) then the regulator is goosed. You might be able to get a regulator pack separately to the alternator (I did on my old 645 - £50 regulator vs. £600 alternator!) but given the cost of a Denso alternator I'd be tempted just to change the lot; better that than doing the regulator now and finding the brushes or bearings give up in six months time.
