Home > General (L494) > 2016 SVR Suspension Fault In Freezing Temps Only |
Chugga90 Member Since: 25 Aug 2014 Location: Bucks Posts: 33 |
Probably something related to the air compressor for the suspension. Not sure where they live on this model.
Sun Nov 10 2019 9:03am |
L494 suspension compressor is in the boot under the carpeted boot floor where the spare wheel lives- have to remove both to get clear access to the battery......... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sun Nov 10 2019 9:55am |
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 374 |
I was assuming a faulty compressor would throw errors more regularly than just cold morning start ups?
Sun Nov 10 2019 9:59am |
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 431 |
Any moisture in an air tank will freeze, ususally in the valve that the air exits the tank.
Sun Nov 10 2019 10:23am |
No idea about the filter Dave B, thanks for the advice will certainly ask the question |
Mon Nov 11 2019 1:52pm |
Well it showed the fault again this morning, but this time it was 5 degrees outside so no freezing conditions to deal with.
Thu Nov 14 2019 12:28pm |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1289 |
Low battery throws all sorts of faults.
Thu Nov 14 2019 9:39pm |
I also have a fault with the intelligent emergency braking and active cruise, Id be really relieved if it ends up being a simple batter issue |
Thu Nov 14 2019 10:39pm |
Diagnosed as a blocked exhaust in the air compressor so the compressor cant vent when it needs to and it triggers a fault, they corrode apparently and the corrosion starts to cause a blockage, LR have changed the design on newer cars |
Sun Nov 17 2019 7:08pm |
