![]() | Home > General (L494) > 2016 SVR Suspension Fault In Freezing Temps Only |
Chugga90 Member Since: 25 Aug 2014 Location: Bucks Posts: 34 ![]() ![]() |
Probably something related to the air compressor for the suspension. Not sure where they live on this model.
L494 suspension compressor is in the boot under the carpeted boot floor where the spare wheel lives- have to remove both to get clear access to the battery......... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 402 ![]() ![]() ![]() |
I was assuming a faulty compressor would throw errors more regularly than just cold morning start ups?
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 432 ![]() ![]() ![]() |
Any moisture in an air tank will freeze, ususally in the valve that the air exits the tank.
No idea about the filter Dave B, thanks for the advice will certainly ask the question |
Well it showed the fault again this morning, but this time it was 5 degrees outside so no freezing conditions to deal with.
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 ![]() ![]() |
Low battery throws all sorts of faults.
I also have a fault with the intelligent emergency braking and active cruise, Id be really relieved if it ends up being a simple batter issue |
Diagnosed as a blocked exhaust in the air compressor so the compressor cant vent when it needs to and it triggers a fault, they corrode apparently and the corrosion starts to cause a blockage, LR have changed the design on newer cars |
