Home > Faults & Fixes > Ace pipes replaced (pics) now juddering
Ziceman
Had ACE pipes replaced body had to be lifted, after driving around all seemed good, then some minor problems accured like windscreen washer not working was washer pump nipple snapped so no problem fixed.
The problem I have and only started after the ACE replacement, drives great but problem seemed to happen same place as I was going daily to a shop with a slight incline parking and when I get back in vehicle reverse feels jumpy and when I drive off come to first traffic lights it starts bouncing up and down drive off and settles down at next stop. I went to a local mechanic he said gearbox oil need changing which was done with all filters and engine oil. He said I need heater plugs as it's rough starting, i left thinking all be ok, NO as I called up at same shop and did the same again Big Cry things I noticed since ACE replaced body lifted my vehicle started up beautiful, I noticed to stop the bouncing is while foot on brake is slightly touch the accelerator.
Could there be a pipe not fitted properly or placing body back on chassis upset the rev settings.
Post #590415 Thu Nov 14 2019 10:48pm
Ziceman
Update: I started it this morning and chugged and smoke from back and first time ever it stalled, it seems to be not ticking over properly, I went 10 mile and thought warmed up be smooth but no it's still hesitate,.
Post #590445 Fri Nov 15 2019 2:01pm
Brit Plumber
I have no idea about your issue but when my ACE pipes needed changing I didn’t lift the body, I bought some 3500bar couplers from the local agriculture machinery supplier and cut the pipes and fitted them that way. Some have managed to fit them without even cutting them but I didn’t have enough room.
It cost £200 for the pipes and £12 for couplers I think it was.
 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #590483 Sat Nov 16 2019 10:58am
Tallchap
United Kingdom 2008 Range Rover Sport TDV8 HSE Buckingham Blue
What pressure do the ARC hoses run at?
Do they corrode and then leak?
TC
Post #590491 Sat Nov 16 2019 4:01pm
Brit Plumber
I think max operating pressure is 350bar. I only went for 3500bar as they were stainless and 20p each dearer.
My pipes corroded around the rubber mount, obviously the protective finish rubbed off under the rubber and then water got in and rotted the pipe. If one goes again I’ll just replace the damaged section although I now try and keep it all clean and try and cover the rubber mount with a dose of Vaseline. 2019 5.0 SC SVA (Current)
Post #590499 Sat Nov 16 2019 6:31pm
Ziceman
Mine corroded under drivers side where it went through chassis, cost £800 total.
Yesterday started and stalled first thing then ran ok until pulling at my destination it was idling erratically making it bounce up and down, slow charged and tested battery just incase, left there -1 degrees at every junction and traffic lights stalled😭😭😭
Post #590547 Mon Nov 18 2019 11:13am
Brit Plumber
£800 isn’t as bad as I was expecting, I would have guessed at over £1000 so that’s not to bad.
Regarding your issue, can you take it back to the garage? It could be fuel starvation or maybe a poor earth? 2019 5.0 SC SVA (Current)
Post #590551 Mon Nov 18 2019 12:41pm
Ziceman
I actually think your right Brit Plumber, today car started ok went and bought diesel cleaner and maf cleaner done both and tonight started perfect and nice drive home no problems at traffic stops then last turn let the power off and stalled in the road to oncoming traffic, it was scary as when it stalled steering locked and Bering wrong way.
Post #590586 Mon Nov 18 2019 11:19pm
Ziceman
Hi all, update incase anyone else gets a similar situation, mine was the fuel pump, he got a second one and running smoothly once again.
Post #591755 Wed Dec 11 2019 12:42pm
daxmatt
Wow,that looked a bit excessive for the pipe replacement,i did mine laying under it in a day.
Granted,it was a bit awkward
Post #591781 Wed Dec 11 2019 9:32pm
Ziceman
I'm not sure why but I think it was impossible to access as leaks was under drivers door going through chassis.
ACE replacement pipes + labour. £800
Gearbox kit replacement and engine oil and filters + labour £350
Fuel pump +labour £700
MOT £30 PASSED YIPPPPPEEEEE.
Post #591801 Thu Dec 12 2019 12:02pm
derekmines
I've got a leak from the same area and I'm thinking that doing the same as you might be the best way forward (I was thinking of only replacing the one leaking pipe but in truth they're all a bit crusty so replacing the lot might be the best way.
Are any of those in your image under pressure at all, or is it simply a case of cut pipes, catch fluid that drains out, fit couplings, refit new pipe and top up system?
Post #611863 Thu Mar 25 2021 10:17am
Brit Plumber
Without the engine running, any pressure will dissipate in no time. If the car isn’t moving then the fluid under pressure is returned to the reservoir. The valve block only opens to allow pressure to the appropriate roll bar if the roll sensor commands it. I made a set up to bleed the system but most don’t bother and I found only a small amount of air bled off after I’d driven it for a few days anyway.
I think these compression joints worked really well for me because the pipes were new. Older pipes with corrosion would likely not seal well at all. If you can, replace the whole lot. In the long run I think you will save yourself a lot of pain. 2019 5.0 SC SVA (Current)
Post #611891 Thu Mar 25 2021 10:07pm
Tom Davison
Sorry to reactivate this thread, but those couplings look neat, and no doubt saved a load of money.
My fronts are on the way, not leaking yet but won't be long. So you bought genuine new ACE pipes then neatly cut at that spot, to enable the installation, then just reconnected?
Post #635166 Sat Aug 19 2023 12:52pm
Brit Plumber
Yes that’s correct, I could have probably just cut out the bad section of pipe and fitted 2 couplers and a new section, but it thought it would only be a matter of time before the next section failed, so I replaced them all with genuine pipes and just cut where I wanted each coupler. You can see I cut the pipes in a way to off set each one (to give space for the spanners) and align them in a tidy fashion, it’s what Land Rover should have done really. 2019 5.0 SC SVA (Current)
Post #635171 Sat Aug 19 2023 6:53pm
