Home > In Car Electronics > In-control
McFarTech
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Orkney Grey
In-control
Hi Guys.
So I have that extra fob that from what I can see will just put the fans on the front windows. Handy. Thought it might have made the inside warm.
However my mate who had a 203 Range seems to think that I should be able to use the iOS app to communicate with the car. I have tried adding my car on the in control site with the VIN but get told it’s not found. Is there something I need to change or upgrade or purchase or was this just not a feature on my Sport?
Thanks in advance.
Craig. ===========================================
2013 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Orkney Grey with cream and black leather.
Post #590077 Fri Nov 08 2019 8:20am
syl
Not sure when the first version of InControl started, but remote start via the app didn’t come in for cars before around 2016. The extra fob you have should heat the entire car though, using a separate little fuel burner. I think there is a timed option too. RRS MY17 SDV6 AB
Evoque MY17 TD4 AB
Post #590082 Fri Nov 08 2019 10:11am
McFarTech
Thanks mate.
It defo clears the windows but I would not say the car was toastie warm. Do I have to set anything temp wise in the car before I use the system? I’ve had a look and don’t see much. ===========================================
Post #590086 Fri Nov 08 2019 10:32am
Brit Plumber
If you have a 2013 L320 you won’t have InControl, it was a later option in the JLR range. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #590091 Fri Nov 08 2019 11:14am
McFarTech
Thanks mate.
Craig ===========================================
Post #590095 Fri Nov 08 2019 11:21am
knwatkins
McFarTech wrote:
Thanks mate.
I think the remote heat will warm the car to whatever your climate control knobs are set to.
I must say, I've started using it again during the last few weeks and I love it. Kev
Post #590110 Fri Nov 08 2019 4:15pm
McFarTech
Thanks mate. Think I will put the heat on the hugest setting and then try it tomorrow morning. ===========================================
Post #590111 Fri Nov 08 2019 4:23pm
Brit Plumber
It also won’t work (I believe) if the fuel level is less than a predetermined amount. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #590112 Fri Nov 08 2019 4:34pm
McFarTech
Ah that’s good to know. Any idea what that level is? ===========================================
Post #590113 Fri Nov 08 2019 4:43pm
Brit Plumber
I’ve got a petrol so never needed to find out but I bet one of the Derv drivers will know. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #590114 Fri Nov 08 2019 4:52pm
