![]() | Home > In Car Electronics > In-control |
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 412 ![]() ![]() |
Not sure when the first version of InControl started, but remote start via the app didn’t come in for cars before around 2016. The extra fob you have should heat the entire car though, using a separate little fuel burner. I think there is a timed option too. RRS MY17 SDV6 AB
McFarTech Member Since: 13 Sep 2019 Location: Kent Posts: 126 ![]() ![]() ![]() |
Thanks mate.
If you have a 2013 L320 you won’t have InControl, it was a later option in the JLR range. 2019 5.0 SC SVA (Current)
Thanks mate.
I think the remote heat will warm the car to whatever your climate control knobs are set to. I must say, I've started using it again during the last few weeks and I love it. Kev MY2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey MY2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
Thanks mate. Think I will put the heat on the hugest setting and then try it tomorrow morning. ===========================================
It also won’t work (I believe) if the fuel level is less than a predetermined amount. 2019 5.0 SC SVA (Current)
Ah that’s good to know. Any idea what that level is? ===========================================
I’ve got a petrol so never needed to find out but I bet one of the Derv drivers will know. 2019 5.0 SC SVA (Current)
