Home > Technical > Instrument panel mileage / trip display - no backlight |
Ians63 Member Since: 03 Sep 2019 Location: NE Scotland Posts: 20 |
As per title - the right hand lcd (mileage/trip) does not illuminate. Everything else is ok. Any ideas? |
Tue Nov 05 2019 6:54pm |
2006 |
Tue Nov 05 2019 9:07pm |
Has it had the issue with the can bus sorted in the past? It may be worth checking the connections on the back. You could also try banging the dash above the binnacle you see if you can get anything to happen. 2012 5.0 SC AB
Thu Nov 07 2019 11:15am |
Only had the car a month so I don’t know any of its history- I’ll try the “technical tap” approach first. RRS 2006
Thu Nov 07 2019 6:27pm |
Gandalf Member Since: 11 Sep 2017 Location: South Killingholme Lincolnshire Posts: 205 |
Ah the Land Rover cure all the 4lb lump hammer if you know what to hit and the 9lb lump hammer if you know where to hit it If it ain't broken down it soon will Pulling my Vanmaster tin tent with my 2005 RED RRS HSE TDV6 1973 Land Rover Series 3 110 safari Gone but not forgotten 1990 Discovery 200Tdi Gone thank god 1996 Discovery 300Tdi sadly missed 2003 Discovery TD5 Gone to LR heaven 2004 Discovery TD5 Gone to Aberdeen hope it likes it there 2005 RRS HSE Rimini Red (my Disco 3 in a posh frock) sadly selling Think I see a pattern here |
Thu Nov 07 2019 8:34pm |
It’s not a cure but if you get some flashes of light you know you have a contact issue. It’s been used to successfully diagnose cluster issues in the past. It’s also a good way to relieve some frustration!! 2012 5.0 SC AB Mods: TPMS Genuine LR DRLs Remote Boot close from key fob 2016 Discovery 4 Mirrors AKA RRS2 2014 L405 Surround Camera retro fit (WIP) 2013 RRS Dual View Screen fit (Complete) 2016 LR4 RSE 2014 LR4 Homelink 2016 FFRR Electrochromatic Wing Mirror Glass 70 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Fri Nov 08 2019 11:04am |
I like that, I’ll try and remember it for next time. 2012 5.0 SC AB Mods: TPMS Genuine LR DRLs Remote Boot close from key fob 2016 Discovery 4 Mirrors AKA RRS2 2014 L405 Surround Camera retro fit (WIP) 2013 RRS Dual View Screen fit (Complete) 2016 LR4 RSE 2014 LR4 Homelink 2016 FFRR Electrochromatic Wing Mirror Glass 70 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Fri Nov 08 2019 11:05am |
Update - it’s working now. No technical tap required. I’ll keep an eye on it and hopefully it’s not a sign of further impending doom. RRS 2006
Fri Nov 08 2019 6:11pm |
