![]() | Home > Off Topic - Other Cars > New Defender shot maybe |
Gingerg978 Member Since: 18 Jan 2018 Location: Berkshire Posts: 67 ![]() ![]() ![]() |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 ![]() ![]() ![]() |
I stand corrected, according to the option pack, once fitted it is not designed to be removed ![]() MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1942 ![]() ![]() ![]() |
Looks like a Kia Soul Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Tomorrow I’m going to the 1st public viewing in Scotland - cars are at the Buchanan Galleries in central Glasgow for the weekend before going south again.[/quote]
Well I went a looked at the 110 HSE D240 that was on display ............ it is very big but in the flesh it is a much nicer vehicle than in the pictures. Looked well assembled and the full leather chairs fitted to the HSE are really very comfortable, enough to make car suitable for those who normally sit in the back and have a man to do the driving! I am impressed with its general fit and finish even though this was a pre-production car. The clearview rear view mirror was really good BUT I couldn’t see how you could clean its camera without stopping, getting out, opening the rear door and scrambling up on the floor to hand clean it - it is located on the roof in the base of the sharks fin antenna but I would think on a wet motorway it would still get very dirty very quickly, I also see a problem with keeping the recessed tail lights clean in the same conditions.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9128 ![]() ![]() ![]() |
It's an aluminium monocoque chassis, not a steel ladder frame. It will require different recovery points and there is no way that LR will have designed it to fit JATE rings. So LR will have designed the chassis to have recovery points at the points where they fit their optional extras - no doubt others will soon have aftermarket versions at much reduced prices.
Thanks for the info RRS, To get recovery points as standard you have to buy the least likely model to go offroad, the Defender X at £72000 before adding an extra. They recess into slots on the rear bumper which will be interesting to see how they stay in place and not rattle. at least you won’t need to go fishing under the car to get at them
It does seem silly, doesn't it? You'd think LR would either have standard recovery points on all of them, or at least have them as standard on the "rougher" versions. The base 90 with recovery points makes sense - the top of the range 110 doesn't. 2012 SDV6 - it's missing a couple of cylinders
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071 ![]() ![]() |
Those points look like tow points to tow a vehicle on solid level ground not recovery points.
LR have stated that they're capable of 6.5 tonnes in a snatch recovery. Determining your actual loads during your real recovery is your problem, I'm sure they'll say. 2012 SDV6 - it's missing a couple of cylinders
"Determining your actual loads during your real recovery is your problem, I'm sure they'll say."
LR aren't saying the recovery points are indestructible, are they? They're saying they're good for 6.5 tonnes. If you can't be sure that you're loading them less than that, then don't do it.
recovery points, same as the D5, basically screw in if you do not order the factory fitted options
an Eiger Grey Defender, courtesy of one of the forum members on Defender2.
