![]() | Home > Maintenance & Modifications > 2012 SDV6 oil change |
OvalAutos Member Since: 02 Jan 2019 Location: Cradley Heath Posts: 130 ![]() ![]() |
The only place you might be able to suck the oil out is through the breather pipe on the left side of the engine near the air filter box. But unless you have a very slim and flexible tube, you won't get to the sump as the breather pipe has a few bends in it.
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 ![]() ![]() ![]() |
The pipe mentioned is the way most garages extract the oil. I have done it numerous times and it gets 6 litres out without problem.
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2021 ![]() ![]() |
Enjoy the read |
Gjlatz Member Since: 01 Mar 2019 Location: UK Posts: 40 ![]() ![]() ![]() |
Many thanks for all your replies. I’m going give the extraction method a go. It would only make sense to me go the sump plug way if the oil filter was down below as well. |
Hello all, the vacuum method is definitely the way forward. 30 minutes from start to finish.
