Home > General (L494) > TRICKLE CHARGING |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4844 |
Fitted this on my RRS1 don't even need to bend down or unlock car to connect or unplug it, also fitted Anderson connector under the bonnet to connect charger to.
Tue Oct 15 2019 10:30pm |
maci234 Member Since: 12 Oct 2014 Location: scotland Posts: 165 |
anderson connector |
Tue Oct 15 2019 10:53pm |
Tue Oct 15 2019 11:00pm |
There is an option with the Land Rover branded charger to have a permanent socket fitted in the grille (I had one on my first Evoque, fitted by JLR gratis trying to stop the battery from flattening in 3 days) so it is possible but I don’t know if any other trickle chargers can be supplied with one. I posted a thread about how to connect up an L494 to a solar panel trickle charger a couple of years ago. I know someone who garages their X5 for 6 months at a time and they have mounted their solar panel outside the garage and extended the cabling to the crocodile clips and that works well. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Wed Oct 16 2019 9:21am |
Three-Six Charlie Member Since: 21 Mar 2019 Location: Wigan Posts: 60 |
I considered this before I bought my RRS as it's not driven every day, so would be left connected to a C-Tek in the garage for most of the week. However, it's so quick to just connect the crocodile clips to the under-bonnet boost points that it just isn't worth the effort of cobbling any alternative up. 2013 L494 5.0 SC in Chile Red |
Wed Oct 16 2019 9:53pm |
Wed Oct 16 2019 10:40pm |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 869 |
Like Col, I use the Ctek comfort connector. His is below the screen, whilst mine is inside the front valance, under the number plate, connected to the charging point under the bonnet. This way, there are no wires rubbing against your paintwork & like his, means you can connect it up while the car is locked & you do not have to open the bonnet to connect & disconnect. Just slip it back into the area behind the valance when not in use
Thu Oct 17 2019 12:39pm |
did you just make up your own connections to connect to points under bonnet or can you buy something to do the job |
Thu Oct 17 2019 9:56pm |
Just need something like this, I think they do them in various lengths and eyelet size as well, but no sure on that.
Thu Oct 17 2019 10:20pm |
You need the M8 size eyelets. If using the comfort connector on the front valance like I have shown, the cables need to be extended. As far as I know the connector cable only comes in one length.
Thu Oct 17 2019 11:10pm |
arwV8 Member Since: 17 Feb 2018 Location: Worcestershire Posts: 18 |
I also use the 13 pin tintenter connection to keep what I think is the main battery (starter) topped off. Not sure which battery the caravan/trailer socket perminent live is connected to. There are two batteries on mine (2016 MY), the aux battery used for the computers during start and engine not running conditions is not connected to the main starter battery circuit for recharging until the engine is running and when the main start battery voltage is high enough, then a contactor closes and allows the aux battery to charge up too. (seen on FFRR site they have a supercapacitor instead of an aux battery from some time in 2016 65 plate onwards so may not have the same charging issue as with twin batteries)
Fri Oct 18 2019 2:59pm |
do you have a picture of what you have done please |
Fri Oct 18 2019 3:55pm |
No problem. Pouring of rain just now will send when it stops |
Fri Oct 18 2019 4:07pm |
thank you |
Fri Oct 18 2019 4:24pm |
