Home > Faults & Fixes > Engine not turning off with key out of ignition |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 |
I had the same problem when I was replacing interior lights and I pulled a fuse, realised it was the wrong one so put it back immediately.
Sat Oct 12 2019 12:14am |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 |
Yeah I hope it's not that fault either Scrumpy.
Sat Oct 12 2019 11:54am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4319 |
BCM is the fuse box behind the glove box |
Sat Oct 12 2019 12:06pm |
I've had a check of the fuses and relays and it doesn't look like these are at fault (unless I'm checking the wrong ones which there is a good chance of)
Sun Oct 13 2019 2:29pm |
OK this sounds bizarre, but here goes... it looks as though the issue I'm having is with one of the relays in the fuse compartment under the bonnet.
Mon Oct 14 2019 2:49pm |
