Home > Technical > Intermittent Wipe
Seamanm
Hi all.
Interesting point about the sensitivity being for the rear only and the stalk pictograms being misleading. I've had a couple of BMWs (1998 & 2006) and a 2006 911 and their rain sensor worked perfectly, starting and stopping the wipers spot on. I've also had a Disco 3 and Disco 4 and now have a 2015 RRS HSE and the rain sensor on the D3 and RRS are terrible!! There is no rhyme or reason to the logic...they fail to start so you're forced to manually turn them on then when the screen is dry they don't stop (when on auto) and flail from side to side on double speed wearing the rubbers out!! My screen is clean and there is no damage so what the 😡 is going on...I don't know!
I'll be raising this with landrover when it goes in for the next service....they need to get some
German logic installed.😂
Post #504481 Sun Sep 04 2016 8:42am
Johnski
Most strange, I have no problem with the front intermittent wipe feature, you turn the rotary dial on stalk one way to increase gap in between wipes and the other way to decrease. The rear wiper on mine though goes three wipes at turn on and one wipe every few seconds, which I have no means of altering. I also have rain sensor, so when stationary the wipers don't seem to move. Of course also continuous wipe and continuous wipe but at a lot faster speed. Never noted any problem. John
Post #504519 Sun Sep 04 2016 9:34pm
ravingmad
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Santorini Black
Mine is same as Johnski,
Not a problem MY13.5 Autobiography, Santorini Black, Privacy Glass. Gone
Driving a milk float for now.
Post #504537 Mon Sep 05 2016 12:00pm
In 2000 BMW had a function which would reduce the wiper selection by 1 when stationary.
So if you had continuous wipe selected, if would reduce to intermittent. etc
intermittent would goto off.
Sounds like that has been implemented on the later RRS.
Post #504543 Mon Sep 05 2016 12:56pm
Stu
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
If i remember correctly on the FFRR, you use the stalk itself to alter the frequency of the rear wiper, eg, if you put it on count to five for example then switch it off it changes the speed, but don't quote me on that, i've slept since then... Embarassed Current: 2010 RRS 3.6 TDV8 HSE
Past: 2012 4.4 TDV8 Vogue
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
1988 3.5 V8 EFI Vogue
Others: 2007 VW Touareg 3.0 V6
1998 Jeep Grand Cherokee 4.0
1990 Mitsubishi Shogun 2.6
Post #588317 Wed Oct 09 2019 6:57am
Lindab
As above, RainX or equivalent. I only need to use an occasional flick wipe when going slow in traffic. Once on the move, 30mph plus, never need to use them as the rain just blows off. The quicker you go the faster it clears In fact I cant remember when they were last used & I live in "sunny" Scotland. Never ever had to use my washers either Thumbs Up
Post #588329 Wed Oct 09 2019 3:08pm
CornishRob
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
This also drives me nuts. I've fiddled with the delay, and it does not alter the rear wiper delay, which seems fixed at 30 elephants Laughing
I can't be sure, but I think it may have worked if I turn the wipers to off whenever I change the sensitivity.
I'll have to go and test it later, now I think about it again Rolling Eyes
Post #588424 Fri Oct 11 2019 8:30am
CornishRob
Right, I think it works better, if when you change the sensitivity setting on the wipers, you switch them off, then back on again.
At least with the current weather, I have plenty of opportunity to try it !
Post #588826 Fri Oct 18 2019 11:39am
carlos50
Just picked up a 2016 SVR and thought my intermittent wipe was broken as it wipes way too fast, it the same speed the same as the on position on mine.
I came from an L405 and never had such an issue so was sure I had a fault, until I read this. May consider the RainX option as wiping them myself with the tap down on the stalk becomes a chore on a 2 hour drive in the light rain we often get that is too light for always wiping setting. Big Cry
Post #589880 Tue Nov 05 2019 11:09am
Bardley
This is the same as on the D4's, and I for one have turned OFF the rain sensor option in the CCF, which then returns the delayed wipers to a conventional adjustable DELAY system..
Post a note in the Disco4 forum, and one of the GAPII PRO tool owners may well be able to do the same for your RR's. 2011 MY D4 HSE
Previously 2001 D2 TD5, 1996 D1 300Tdi, 1985 90 2.2 petrol.
Bikes! KTM, BMW, British, Classics and others.
Post #589904 Tue Nov 05 2019 1:53pm
knwatkins
Same here. It's a small thing, but having control of intermittent wipe is very satisfying! Kev
Post #589908 Tue Nov 05 2019 2:08pm
bmszabo
Netherlands 2013 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
In my experience, intermittent sensor can be fooled by car wash, especially with wax/other treatments. After car wash (with wax) intermittent sensor gets over sensitive, cleaning the sensor area with a towel solves the problem. As far as I see, not a sensor problem, my Mercedes before had the same issue.
Post #590163 Sat Nov 09 2019 7:13pm
Brit Plumber
It must be just mine that works fine for me. I have it on Auto and it works with no issue. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #590166 Sat Nov 09 2019 8:28pm
derekmines
Oh I do hope so... the auto-wipe function on my RRS is almost as useless as the one on the X1 that i had previously... what I wouldn't give for normal intermittent wipe!
Post #590329 Tue Nov 12 2019 7:49pm
