![]() | Home > Technical > Straighten headlight beams |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9128 ![]() ![]() ![]() |
The direction can be adjusted using two screws on the back of each unit. Whether there is enough adjustment for your needs will require some experimentation. 2012 SDV6 - it's missing a couple of cylinders
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 411 ![]() |
using the adjustment screws wont work if they are adaptive headlights..
Ljdiscovery Member Since: 30 Apr 2016 Location: La Jolla, california Posts: 42 ![]() ![]() ![]() |
Thanks for the replies. They are as adjusted as they will go. I have tried a hard reset several times, the lights just don’t move any longer. Can they be adjusted from inside the headlight housing? Phil |
