![]() | Home > In Car Electronics > Dreaded parking sensors |
david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166 ![]() ![]() ![]() |
Certainly shows it being fitted there on the advanced factors site. It's not fallen off and sitting at the bottom of the panel is it?
Aston John Member Since: 17 Apr 2017 Location: Lowestoft Posts: 4 ![]() ![]() ![]() |
Found it!!! I hadn't delved deep enough, trouble is it hasn't fixed the problem, fitted new sensors with no success so had diagnostic check, came up as module fault, so then fitted new module still got the five second bleep £250 spent for no result 😡😡😡 |
Wiring loom corrosion, it’s a common fault, pull the bumper off, it doesn’t take long. 2019 5.0 SC SVA (Current)
Gandalf Member Since: 11 Sep 2017 Location: South Killingholme Lincolnshire Posts: 205 ![]() ![]() ![]() |
Been there new sensrs and looms front and back still get the same faults so ![]() Pulling my Vanmaster tin tent with my 2005 RED RRS HSE TDV6 1973 Land Rover Series 3 110 safari Gone but not forgotten 1990 Discovery 200Tdi Gone thank god 1996 Discovery 300Tdi sadly missed 2003 Discovery TD5 Gone to LR heaven 2004 Discovery TD5 Gone to Aberdeen hope it likes it there 2005 RRS HSE Rimini Red (my Disco 3 in a posh frock) sadly selling Think I see a pattern here |
Where did the sensors come from? There are some expensive sensors that have been causing issues, not saying it’s the same fault but genuine have fixed it. I think the bad ones were about £40 each so not cheap. 2019 5.0 SC SVA (Current)
The part number is YDB500370LML but I see lots of copies are being sold with that pt no. You want some in genuine packaging, occasionally they are on eBay for a good price, I paid £8 for mine about 7 months ago. 2019 5.0 SC SVA (Current)
New rear sensors were from EBay £35 for 4 did the trick at the time but maybe buy cheap buy twice, fitted a month ago?
Check your wiring first as it only takes one bad wire to take the whole lot out. 2019 5.0 SC SVA (Current)
Not sure if it makes any difference but that part number is listed for the 2002-2009 L322 Fullfat, facelift sport is LR010927 superseded to LR038084
It’s the same part, they even fitted them to the water wading on the L405 and L494. I’ve a feeling the last 3 letters were a code for the paint finish but they all come in primer now. 2019 5.0 SC SVA (Current)
LML does mean finished in primer, not sure they are all the same though as L/R use completely different part numbers for all models. Microcat specifically list different part numbers for different models, as some have different angled connector/pin configuration as well as locate differently. Personally seeing how much trouble these sensors can be I think I would use the one's specifically listed for my vehicle, as opposed to one's that might be the same.
Ok so I think there may be an issue with packaging, I googled the part number I quoted and the packaging is correct but the contents aren’t the same, the pt no on the bag is YDB500370LML but the part number on the sensor is FK72-15K859-CA.
Not sure what number are on the actual sensor but this is the difference visually, first picture being facelift RRS1. Always a bit of a gamble I guess with the likes of ebay, as half the time the sellers don't know what they are selling and list it to fit 05-13 cars when they clearly don't.
So the style of sensor is that of the top one but the packaging is that of the bottom one. The bag was sealed but it could easily have been re-sealed. I actually got it for the water wading mirrors rather than for the PDC. 2019 5.0 SC SVA (Current)
