Home > In Car Electronics > Dreaded parking sensors
Aston John
England 2010 Range Rover Sport 3.0 TDV6 HSE Baltic Blue
Embarassed Parking sensor module, does anyone know where it is located on 2010 HSE, have got anew one part No. LRO24774 but can't find where it belongs, thought it was behind left hand side boot panel below window, there are brackets but nothing on them
Does the 2010 facelift model have a different system?
Post #587716 Sat Sep 28 2019 2:55pm
david007
United Kingdom 2011 Range Rover Sport SDV6 SE Vesuvius Orange
Certainly shows it being fitted there on the advanced factors site. It's not fallen off and sitting at the bottom of the panel is it?
https://www.advancedfactors.co.uk/parking-...2710-c.asp
Post #587718 Sat Sep 28 2019 3:46pm
Aston John
Found it!!! I hadn't delved deep enough, trouble is it hasn't fixed the problem, fitted new sensors with no success so had diagnostic check, came up as module fault, so then fitted new module still got the five second bleep £250 spent for no result 😡😡😡
Post #587723 Sat Sep 28 2019 6:55pm
Brit Plumber
Wiring loom corrosion, it’s a common fault, pull the bumper off, it doesn’t take long. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #587729 Sat Sep 28 2019 9:12pm
Gandalf
Been there new sensrs and looms front and back still get the same faults so Censored it I'm not spending any more If it ain't broken down it soon will
Pulling my Vanmaster tin tent with my 2005 RED RRS HSE TDV6
1973 Land Rover Series 3 110 safari Gone but not forgotten
1990 Discovery 200Tdi Gone thank god
1996 Discovery 300Tdi sadly missed
2003 Discovery TD5 Gone to LR heaven
2004 Discovery TD5 Gone to Aberdeen hope it likes it there
2005 RRS HSE Rimini Red (my Disco 3 in a posh frock) sadly selling
Think I see a pattern here
Post #587750 Sun Sep 29 2019 10:18am
Brit Plumber
Where did the sensors come from? There are some expensive sensors that have been causing issues, not saying it’s the same fault but genuine have fixed it. I think the bad ones were about £40 each so not cheap. 2019 5.0 SC SVA (Current)
Post #587752 Sun Sep 29 2019 10:32am
Brit Plumber
The part number is YDB500370LML but I see lots of copies are being sold with that pt no. You want some in genuine packaging, occasionally they are on eBay for a good price, I paid £8 for mine about 7 months ago. 2019 5.0 SC SVA (Current)
Post #587753 Sun Sep 29 2019 10:53am
Aston John
New rear sensors were from EBay £35 for 4 did the trick at the time but maybe buy cheap buy twice, fitted a month ago?
Will get genuine front and rears and new looms if that doesn't work I'll pull the fuse or set fire 🔥 to it 😡😡
Thanks for your ideas👍
Post #587759 Sun Sep 29 2019 4:09pm
Brit Plumber
Check your wiring first as it only takes one bad wire to take the whole lot out. 2019 5.0 SC SVA (Current)
Post #587771 Sun Sep 29 2019 10:02pm
Not sure if it makes any difference but that part number is listed for the 2002-2009 L322 Fullfat, facelift sport is LR010927 superseded to LR038084
Post #587774 Sun Sep 29 2019 10:52pm
Brit Plumber
It’s the same part, they even fitted them to the water wading on the L405 and L494. I’ve a feeling the last 3 letters were a code for the paint finish but they all come in primer now. 2019 5.0 SC SVA (Current)
Post #587775 Sun Sep 29 2019 11:12pm
LML does mean finished in primer, not sure they are all the same though as L/R use completely different part numbers for all models. Microcat specifically list different part numbers for different models, as some have different angled connector/pin configuration as well as locate differently. Personally seeing how much trouble these sensors can be I think I would use the one's specifically listed for my vehicle, as opposed to one's that might be the same.
Post #587776 Sun Sep 29 2019 11:29pm
Brit Plumber
Ok so I think there may be an issue with packaging, I googled the part number I quoted and the packaging is correct but the contents aren’t the same, the pt no on the bag is YDB500370LML but the part number on the sensor is FK72-15K859-CA.
Maybe that’s why it was only £8 LOL. 2019 5.0 SC SVA (Current)
Post #587777 Mon Sep 30 2019 7:51am
Not sure what number are on the actual sensor but this is the difference visually, first picture being facelift RRS1. Always a bit of a gamble I guess with the likes of ebay, as half the time the sellers don't know what they are selling and list it to fit 05-13 cars when they clearly don't.
Post #587780 Mon Sep 30 2019 8:50am
Brit Plumber
So the style of sensor is that of the top one but the packaging is that of the bottom one. The bag was sealed but it could easily have been re-sealed. I actually got it for the water wading mirrors rather than for the PDC. 2019 5.0 SC SVA (Current)
Post #587783 Mon Sep 30 2019 9:29am
