![]() | Home > General > 2012 sport no power on passenger side |
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849
Second one suggests that a module isn’t the same engineering standard as it should be, for example fitting a LR4 door module on a RRS. If nothing works on that side then it sounds like a connector is not installed correctly. Drop the glovebox door and look at the connectors, there’s some on the front, some on the back and some on the bottom edge. After that check the connectors on the inside bottom of the A pillar and also check the earths are clean and tight. 2019 5.0 SC SVA (Current)
U2101-00 Car config data transmitted by CAN does not match adaptive damping system control module internal configuration.
| Steven 17 Member Since: 25 Sep 2019 Location: Wolverhampton Posts: 43
Hi mate thanks for that info on replacing the module I just gave the part number and presumed it would be like for like replacement.do you have any idea where I could get the sort of software from which would help me better in searching these faults.ive checked all fuses in the glovebox and physically dropped the fuse box out to check all connections which all look good |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155
Not going to pretend to be auto electrician, but might be worth checking this connector behind fuse box, Pin No. 26 Yellow /Red wire or pick it up at door plug/connector as appears to be feed to door module, only a suggestion.
Ok but I will give that a check tomorrow.i did pull that plug out earlier to be fair and couldn’t see any sort of damage. |
By any chance does anybody know where I could find a diagram of the wires I should be testing and what voltages/continently I should be getting on the wires? Would be a massive help |
The problem is that you need so many diagrams to ID all the wires and I’ve not found a 2012 wiring download that has everything.
So everything I’ve noticed not working so far is
Have you checked all the plug/connectors behind the lower kick panel on the passengers side "A" post, as every thing which is not working appears to be connected to the main harness under there. Not sure it will be a door module as both N/S/F and N/S/R would have had to have failed.
Agree with Col, I doubt it’s a door module, I think you need to take out the kick panel and lift the carpet and check all connections for corrosion etc.
So I’ve taken the kick trim off this morning and lifted the carpet front and rear passenger sides.i found two little puddles of around say a 5ml syringe so not very much at all.ive visible inspected the loom in the door well and can’t see any signs of corrosion or any damage to any of the wires.im stuck on what to try next now. |
The fact there is any water there isn’t particularly good.
Out of interest, have you checked your rear passenger tail lights? 2019 5.0 SC SVA (Current)
Mate if you could find any diagram at all would be a big help.ill give the indicator idea a go later on and see what I find.as far as the rear passenger light I’ve checked everything visually and it’s all working fine bar the indicator on the passenger side door.ive unplugged the rear light to and reconnected it but still all the same. |
| All times are GMT |
