![]() | Home > Maintenance & Modifications > Failed wheel-bearing... |
That’s proper FUBAR’d 2019 5.0 SC SVA (Current)
You don't want to be wearing those shoes when it's raining |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 ![]() ![]() |
It went through is MoT a couple of weeks ago without comment. The "woomp, woomp, woomp" noise was the first sign that I noticed. I'd had some weird noises recently (and before the MoT) that were eliminated with a change of power-steering fluid.
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
Had an advisory for a wheel bearing on mine last month - so far I can't hear the tell-tale whomp, but do hear the occasional 'whirrr' that goes away if you unload one side of the suspension.. doesn't look like a terrible job; undo hub nut, undo four bolts, refitting is the reverse of removal? Of course, I base that purely on looking at the part itself..
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
easy enough forthe front, but getting the old ones off requires a bit of brut force.... I ended up using a full on sledge hammer to knock the old hub out... the neighbours looked very worried when was swinging it at the car |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 784 ![]() ![]() ![]() |
Have a look here; https://disco3.co.uk/forum/topic116658.html |
Thanks! That actually looks quite simple.. he says, clearly cursing himself to suffer several snapped bolts and a broken wheel speed sensor |
I'm not saying I would do it myself.... |
Though not on a LR, when having problems in separating chunky bits of metal, I have spurned the sledge-hammer in favour of a blunt bit in an SDS drill in 'hammer' mode. Tapping all round broke the bond due to corrosion. |
Handy tip! 2019 5.0 SC SVA (Current)
jason-nike Member Since: 08 Nov 2013 Location: sussex Posts: 207 ![]() ![]() |
My front wheel bearing was going on my 2011 Sport.
I'd probably lop the end off an air chisel bit and use the air chisel, but .. same idea - good tip indeed ![]() Mind, I have a range of legged pullers if I do decide to do it myself; just nothing to "suck" the stub back into the hub (the second half of the LR SST).. probably a good shove and using the hub nut will do; that's certainly worked before for me on other cars ![]()
Including pads that's really not bad at all .. if I'm feeling lazy I'll give New Duston Garage a call and see what they quote .. ah, heck, let's do it now .. £276.48 excl brake pads, less if it only takes them an hour. Not bad at all. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
It cost me £305 inc VAT, for an OEM bearing, clearing all faults and a road-test. Having it collected and dropped-off made the whole thing painless. It would have cost me that in lost time to do it myself and my neighbours were spared all the swearing.
