Home > Maintenance & Modifications > Interior LED light upgrade front doors not working |
Have you tested them on the rear doors and they work?
Wed Sep 18 2019 12:29pm |
ryan_holton Member Since: 07 Jul 2019 Location: Bridgend Posts: 26 |
I’ll try this later. I’m 99% sure that the 2 LEDs left are working, however, does it need to be a full 20 minutes of waiting? Because if I happen to put it in the wrong way round, I’ll have to try again and wait about 20 mins? Waiting a total of 30 mins? |
Wed Sep 18 2019 2:11pm |
The 20 minutes gives the BCM chance to go to sleep. It’s pretty much to the second as I was testing my car for a Quiescent current drain a few weeks back and witnessed every time. 2012 5.0 SC AB
Wed Sep 18 2019 2:49pm |
Reporting back with an update here... I followed your guidance, and they now work. I’ve vetoed the LEDs are working, however, they seem to be inconsistent now, sometimes they’ll come on, sometimes they won’t, if I unlock the car with keyless entry they seem to work consistently, but if I unlock the whole car with the key, they don’t come on, the other LEDs work fine, and there’s no warnings, but locking, unlocking and doing the whole engine start fixes it temporarily though, just seems odd unlocking the car would mean they don’t work as opposed to using keyless entry |
Wed Sep 18 2019 7:34pm |
Do you have wing mirror puddle lamps and/or lamps in the wing mirrors?
Wed Sep 18 2019 7:54pm |
I do not have the puddle lights on the wing mirrors. However, prior to installing the LED T10 bulbs into the doors, the front passenger and drivers puddle light under the door would illuminate regardless of how I lock/unlock the car, and regardless of whether I'm in the car, or not.
Wed Sep 18 2019 9:22pm |
I think you may need to try another brand of LED, the BCM is maybe detecting them as either high resistance or open circuit. Can you access the DTC as I bet some will be logged. 2012 5.0 SC AB
Thu Sep 19 2019 4:00pm |
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 192 |
I gave up on LED's in the bottom the doors, I could never get them to work. There must be something in the door control module that doesn't mix with LED's. Otherwise the fine in the rest of the car, including the reg plate. 2018 Telsa MS
Thu Sep 19 2019 9:06pm |
I’ve got projectors in the bottom of my front doors. I bought 2 identical sets and both right sides blew in about 2 months. I then bought another set that were slightly different so changed the slide from the blown ones into the new ones and they’ve been fitted since Aug 2018 now. It’s like they’ve settled down now. 2012 5.0 SC AB
Thu Sep 19 2019 10:11pm |
Swagmeister Member Since: 08 Jul 2019 Location: West of Scotland Posts: 31 |
I changed all my bulbs to LED, 2010 RRS, everything worked apart from the puddle lights in the bottom of both doors, rear door puddle lights worked, front didn’t. Gave up in the end and went back to original bulbs. |
Fri Sep 20 2019 10:07am |
Sinook Member Since: 06 Oct 2020 Location: Bonnyrigg Posts: 6 |
Hi I have changed all interiors to led and they were fine to start , every now and again they have started flickering ? Also changed the brake light bulbs to led and can’t remember if it was after or before I swapped them that I now get gearbox error on the dash ? Anyone had similar problems cheers |
Tue Oct 06 2020 2:10pm |
Tue Oct 06 2020 2:14pm |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 386 |
Hi Sinook,
Tue Oct 06 2020 11:31pm |
Regular pulsing of the LED indicates a comparability issue, irregular flashing would suggest the LEDs are cheap. I fitted mine about 2 1/2 years ago and they are still going strong, they weren’t cheap but they’ve lasted.
Wed Oct 07 2020 9:10am |
